There is a delay on the keyboard and on the mouse. I can type up to 20 letters of so with nothing showing on the screen. The same is true for moving the mouse to a location. It takes multiple seconds for the mouse to show its location.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 179 Answers
Change keyboard
Posted on Aug 28, 2010
My keyboard typing multiple letters
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard\'s repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
If fails
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean
If you are still feeling industrious, next you can tackle cleaning your mouse Of course, if cleaning your keyboard seems a truly undesirable task, you can always buy one for around $20.
Hope this helps.
Dec 31, 2012 | HP Computers & Internet
When typing I can see letters with 3sec delay on the screen
This is not keyboard issue
if you are using windows xp , do the following
goto RUN
type %TEMP% enter
and delete all files, then restart computer
then you can check
thank you
Jun 30, 2011 | Compaq Keyboard
Yes I'm on xp. The taskbar lettering turns grey
try this:
1. From the start menu, Click on Run then type “dxdiag”
2. Click on the “More Help” Tab then click the “Override Refresh Rate” Button.
3. Set the refresh rate override value to 60
Jan 30, 2010 | Computers & Internet
I cannot type double letters without waiting between letters. This is true with backspacing more than one space at a time.
Try changing the Typematic Rate
Go to the BIOS configuration and set the :-
Typematic Rate (Chars/Sec) to 6
and
Typematic Delay (Msec) to 250
Dec 09, 2009 | HP CPQ175KB Keyboard
Missing letters when typing, slow register to screen
the best thing to do is set the delay on your kboard by your control panel-keyboad-thenn select an option.. hope this will help
Sep 29, 2009 | Gateway 2520915 Keyboard
Rt7d40 dell keyboard is non responsive
probably need to clean your keyboard
check keyboard settings in control panel
Nov 13, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft wireless optical desktop 2000 - keyboard and mouse
There are a number of things that may be causing your problem.
The first thing I would check would be the batteries, with these units having a wireless connection if the batteries become weak they will transmit a weaker signal and thus make it harder for the unit to read. Battery life is variable depending on how often you use your keyboard and mouse, and how far away from the transmitter the keyboard and mouse sit.
Also because the units are wireless there may be interference coming from other wireless devices in your household. Some possible guilty devices maybe cordless phones, Wifi adapters, and even some remotes.
Also Have you installed the intellitype and Intellipoint software for your Mouse & Keyboard. If so you can use it to check your battery life/ signal strenth and set you mouse sensitivity and type repeat rate.
On the bottom of your keyboard & Mouse and on the top of the wireless transponder there are reset buttons. Pushing the transponder 1st and then either or both the mouse and keyboards buttons should resysnc them without the need for a reboot.
Hope this helps
Dave
Nov 06, 2008 | Microsoft Wireless Optical Desktop Comfort...
No letters on screen
You need to reboot the PC and it will be fine.
Otherwise, if your mouse is working then go to the device manager and uninstall the keyboard and then restart the PC with Keyboard Driver Installation CD/Setup.
Let me know if you face and difficulty and need further assistance, I will assist you further to fix the problem.
Best of Luck & Have a Nice Day Puneet
Oct 06, 2008 | Logitech Wireless Access Duo Optical...
Letter writting problems
Do you use a laptop or some sort of keyboard with a mouse pad? My son used to have that problem when he would type as his thumb would accidentally hit the mouse pad and move the cursor. We solved it in a very low tech way by taping a notecard over the mouse pad when he was using the computer. Depending on the manufacurer, there are ways to turn off the mouse pad while continuing to use a mouse.
Dec 24, 2007 | Microsoft Digit Media Pro bx100005...
Computers & Internet Logo
David Payne
David Payne
