Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I Have a Versa 055, fires up ok but after a short while shuts of then relights instantly twice after repeated shut downs. then stops lighting up. if switch of and on it will again go through same sequence, but only runs for a short period. ( 15 mins max)
  • 3,083 Answers
Some part is heating up and failing, but I'm not familiar with these units. Here is a web page that has a pdf document about this unit, and perhaps it will be of help:
http://www.raypak.com/FTP_View.cfm?Client_ID=22&FTP_MainCategory=P#Startup%20Check%20List
If you scroll down, you will find your unit. I'm having a problem with Adobe Reader on my computer, so I can't view it to discern the problem. If the unit has a thermocoupler, which most gas systems have, it could be going bad, causing the gas to shut off. Look for that part- it's constantly in a flame, and is the most likely component to fail.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 28, 2010
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
The tv will instantly shut off after its powered on. I did a self check by holding the menu and input buttons for 5 seconds and the green power light in front blinked twice then paused, and blinked twice...
this is error 22. which is a short curcit protection error. the first suspects in this case is the convergence ic (stks) these are supplied by 24 and -24 volt lines. these short and shut the set down.
Oct 16, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Have to light the pilot every morning, then furnace fires up but fan short cycles for about 4 minutes then goes off and comes back on.When the fan goes off the burners stay on. Will do this for a while....
hi clean the air filter , then clean the the afc sense at the bask of it , try this sounda as it is over heating and shutting of on the fan over heat
Feb 17, 2010 | Heating & Cooling
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
263 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
