Question about Tomtom ONE GPS Receiver
My tomtome one
Could you help i need to put my tom tom one to the right setting for me to drive a hgv because it took me throw a one way root as if i was driving a car but im using it at work as im a hgv driver thanks very much hope you can help
  • gripo May 22, 2008
    i have a tom tom 1 and need to knw the right setting for hgv drivers as im getting plms with bridges to low for the truck, its ok if im driving a car but need to knw how to set this for hgv please help. thank you mr clive griffiths.
    e-mail karenparfitt005@aol.com
I have a Tomtom One but can get no where on it as I put in the wrong country. I need a way to chanbe the country to USA please.
Posted on May 07, 2008
Tom tom 910 no maps found after upgrade on tom tom home
conect to computer go to tomtom web site call them. they will have to help you remove all maps from gps.then you will have to reinstall them. it took me 4 days and the right person but it worked.if you do not have usb conection to computer it will not work.
Jan 28, 2011 | Tomtom GO 910 GPS Receiver
Where do i go to update my tom tom with european HGV instructions
Go to the TomTom website. Download and install the Home Application (if you did not get a CD_rom with your device). Run the HOME application and click Update my device first. If you device has been recently put into service (less than 30 days) you may have the right to update the maps free of charge. If not you will find maps to buy.
Here is the link to TomTom.
Feb 20, 2010 | Tomtom One XL GPS Receiver
Cannot get our new Tomtom GPS one 130 to show English in instruct
Connect your device with TomTom Home and access the memory (like if it was an external disk)
Create the following 2 files without ant extension in the root:
cleanflash
runclean
It will reset your devide to the original settings.
When starting it will ask you which language you want to use.
Jan 01, 2010 | Tomtom ONE 130 GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
I tried to put an SD card in my tomtom ONE XL and now it won't do anything...it is flashing what looks like a hard drive and there is a red X over the picture of a hand.
Remove the SD card
then just copy ALL the files from the tom tom to your sd card
It should now work
Aug 26, 2009 | Tomtom One XL GPS Receiver
Tom tom one 3rd ed only turn on one time now it will not turn on
Hello, Unplug your Tomtom device, batteries should be fully charged. The tricky thing to Tomtom devices is the ROM put into the device. It needs to be reset once in awhile. The soft reset is like formatting a hard drive but leaving the system files alone. At the bottom of the device, there is a reset button. You'll need to use the end of a paperclip to reset the unit. After it's reset, reinstall the Tomtom application only by using the Tomtom Home application. Let it reset itself and come back to the original screen, then go to menu and set your preferences. Also if it's connected to Tomtom home and if you backed up your data to your computer, reinstall your maps. The only time your Tomtom device gets bogged down and won't finish a reinstall is when all 1 GB of memory is used up. Hope this helps.
Jan 11, 2009 | Tomtom ONE 3rd Edition GPS
Cannot acces my Tom Tom drive
Is the tomtom showing as an external drive if you access it via my computer on your pc.
If it is showing as a external drive you should be able to copy and past the files back to you tomtom
Just out of interest for what reason did you need to formatt your tomtom.
Jan 07, 2009 | Tomtom ONE 3rd Edition GPS
TOM TOM Fix
yea you are right about the format fixing the issue....the problem with what you said,......is that once you format the unit ALL info is erased...So publically informing people to format their device is not fully correct.....If you are going to attempt to format....MAKE SURE THAT YOU HAVE MADE A BACK UP YOUR UNIT FIRST......this way you have info to put on it....
Jul 10, 2008 | Tomtom ONE GPS Receiver
Tomtom 910 help please
1 Have you got Tom Tom home installed on your PC?
2 Have you got Tom Tom in the home 'cradle' with the usb lead attached?
I have both and have no proba at all
Feb 03, 2008 | Tomtom GO 910 GPS Receiver
TomTom 520 won't start
Hi all,
I got the following response to this little problem. Will try it out and hopefully my 520 will work again soon.
To ensure that your device is correctly connected to your PC, please do the following:-
STEP 1 Run the Registry Cleaner Tool
• Disconnect the TomTom and remove any USB devices from your PC, If you use a USB Hub, please disconnect that also.
• Run the RemoveRegEntries tool. You can download it from :-http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 2 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
• Connect the TomTom to a USB port on the back of your PC. We strongly suggest that you use a USB 2.0 port and not a USB 1.1 Port. (USB 2.0 ports are faster USB ports, which are standard on all modern PC's, older PC's and some laptops may still use USB 1.1 ports which are slower and can prevent some USB devices from connecting properly).
STEP 3 Switch the TomTom On.
• On your PC, open My Computer
• Now switch the TomTom On while it is connected to the PC with the green light on.
• Look at My Computer, do any disk drives appear as you switch the TomTom On? If so, which drive letter is it?
• Double click on the TomTom disk.
• What files and yellow folders do you see?, please make a note of them and reply back with what files and yellow folders you see. If possible, please provide us with a screenshot showing all the details.
If the device is NOT listed as a 'Removable drive' under 'My Computer' when you switch the TomTom On, try the following:-
STEP 4 Check Device Manager
• Disconnect the TomTom from the computer.
• It is likely that you have a Firewall on your PC, in some cases, Firewalls can prevent USB devices from being recognized by the PC. We suggest configuring your Firewall and security settings to allow all USB devices to connect to your PC. Once you have done this, we suggest trying the steps above again.
• Go to 'Start' and right-click on 'My Computer' and select 'Properties'
• Select the 'Hardware' tab
• Expand 'Disk drives'. If the TomTom device is shown there with a red cross, right-click on it and select 'Enable'
• Check under 'My Computer' to see if the device now shows up as a 'Removable drive'.
We also suggest it is a good idea to try to connect your TomTom to another PC to see if you get the same problem.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
90 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
