Hi I have a grasslin timer Model Towerchron QE2, I went to switch heating on and the display is not lighting up, canot use hot water or heating. Checked fuse, ok. can you advise me please
Mine has just developed the same fault, did you find out what the problem was.
Thanks..Roger
Posted on Dec 05, 2011
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
Oct 11, 2014 | Water Heaters
Problem with Grasslin Towerchron QE2
1) Contact Grasslin UK for warranty coverage:
http://www.grasslin-controls.co.uk/contact.html
2) Reset timer and reprogram.
Move slide switch to to right 'set own program'
Then when times are programmed, move slide switch fully right to 'run own program'
http://www.tfc-group.co.uk/assets/graphics/static/QE1-QE2_GB%20instructions.pdf
3) Test that unit is receiving at least 80% rated voltage 240V x 80% = 192V
4) Buy another unit
Jan 29, 2013 | Hardware & Accessories
How do you override the timer if you want to turn off or on outside the preset timer programme
1) Is this the Towerchron QE2?
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB instructions.pdf
2) Page 8: While slide switch is in run-own-program or run-preset-program mode, you can override by pressing select button until arrow points to Boost, or arrow points to ADV.
This will reverse program until next set point.
3) Add comment and describe which timer you have.
Jan 29, 2013 | Water Heaters
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
929 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
