Question about Bush RPA 1 Turntable
Hi , I bought a bush turntable from Argos (oxford street London) last November. Took the unit to India. its an absolute beauty. Unfortunately one day due to voltage fluctuation it stopped working. when I took the unit to a professional, he told me the transformer (20watt) got damaged and needs a repairing. and when he tried to replace an equivalent transformer though the LEDs are blinking but nothing happens there after. I wonder its a problem with the IC, which I was told even by the repair store. please suggest what to do..as i wonder if the parts are available in India or not..need you HELP !!!!
chrispurs1
  • 372 Answers
SOURCE: bush 2871ntx need to reset values/check pic
Hi.
From memory check resistor R603 its either 2R2 ohm or 2R7ohm, Check the large polyester HV caps for bulging & dry joints.
Chris.
Posted on Nov 25, 2007
Danmart
  • 291 Answers
SOURCE: BUSH BTV19SIL NOT LOADING TAPES
There is a small CAM under the foward\reverse takeup wheel. Like a combination lock, must be set in proper sequence to send a signal to eject or load tape. Panasonic VCR has them also.
Hope that this helps, Buddy
P.S. The motor\rubber assembly MUST be set in such a way that the "end of Rubber band line" reaches a certin point WITHOUT turning any more then neccessary because it wll through the switch off aligement.
The LED that the VHS tape covers when it comes down on top of and covers it will give the same problem when it is " caca ".
Posted on May 12, 2008
  • 69 Answers
SOURCE: BUSH IDLCD32TV006
Try replacing the cable.
Posted on Oct 05, 2008
SOURCE: Bush 29" Flat Screen TV IN INDIA CITY OF CHENNAI NEEDS REPAIR.
Please contact below address for Madras branch as they are authorised Bush service centre
Location : U/12 A, Yogi Complex, New Rander Road, Surat - 395009 Phone : (0261) 3066848, 6548278 Regards//Ravin//London
Posted on Sep 18, 2010
gopakumarg43
  • 74482 Answers
SOURCE: HI I HAVE A ARGOS BUSH LED 32S MART TV LE32127HDCNTD THAT KEEPS TURNING ON AND OFF AND NO LOGO ON THE SCREEN I HAVE REPLACED EVERY PART IN THE TV STILL NOTHING
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Sep 11, 2016
Testimonial: "ALL READY REPLACED ALL THE B OARDS IN THE TV"
Exploded view of swingarm bushings on it 06 street Bob
Hi, Freddie for this scenario you will need your service/owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
The Stiffey Swingarm Stabilizer Bushings from Rivera Primo Available at...
Exploded view of swingarm bushings on it 06 street Bob Google Search
https://www.carlsalter.com/pdfs/Harley_Davidson_FLHRC%202006%20Maintenance%20&%20Repair%20Manual-Full.pdf FREE
Harley Davidson DYNA Models Workshop Service Repair Manual 2006 $8 very cheap
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
May 20, 2017 | 2007 Harley Davidson FXDB Dyna Street Bob
Bush hdmi port broke?
hi just take it back get a better make tv like a panasonic thanks
shaun
Apr 17, 2017 | Televison & Video
Need bushtv code for sky remote lc39gl12f
If you have purchased This Tv Bush LC39GL12F from Argos, there is not a code available and Argos do not forsee a code being available in the near future.
I was advised to call Argos Customer service on 0845 6403030 to log a complaint as to no code and eventually a code maybe made available..
NO Good Ringing Argos Tech support, Ring 0845 6403030 Argos Customer Service.
Dec 03, 2012 | Bush Televison & Video
Replace the needle on Bush RPA1
Take the whole unit, open the window, toss the unit out the window and replace with something decent as this TT is a pile of junk and is probably ruining your records. Problem solved.
Nov 28, 2012 | Bush RPA 1 Turntable
Delonghi microvave replacement bulb, microwave only 6 months old
I got a Delongi Mic form argos too ,model ED8525S-SBD, sounds like a similar problem to what happened to it last year. Issue is that the bulb explodes (mainly due to the very strong spring on the door I think) leaving filament lieing on the metal chassis, hence the trip switch in your fuse box trips.
Didn't manage to find a replacement bulb but at least if you remove the old bits then it will get the machine back up and running and stop the trip tripping!
Take off the top by removing the 4or 5 screws around the outer edge at the back. The bulb sits directly behind the front panel inside its own metal chassis. There is a diamond shaped black plastic flange which the 2 power wires feed onto. 2 metal lugs hold this inside the chassis. straighten the lugs and the bulb holder pulls out. Even with the bulb removed I think there was a blown fuse and I had a further issue with the turntable not turning(this feeds off the same circuit as the bulb). So maybe Argos were right - the machine only cost £80 at the end of the day!
Jan 31, 2009 | DeLonghi Ovens
Jun 13, 2008 | Bush 2871NTX 28" TV
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Bush RPA 1 Turntable Logo
90 people viewed this question
Top Bush Audio Players & Recorders Experts
 Grubhead
Grubhead
John
Are you a Bush Audio Player and Recorder Expert? Answer questions, earn points and help others
