When my toshiba s1900 is switched on it turns itself off immediately It will only run on mains as I expect the battery needs replacing I want to retrieve some photos from the hard drive
  • davidm5893 Aug 28, 2010
    Hello thank you for your reply I tried to turn on my computer without the battery installed but it made no difference it still switched off almost immediately Regard David
  • 4,737 Answers
Have you tried without the battery installed? If not, remove the battery and connect (plug in) the AC adapter and power on the Machine. If the problem is with your battery, it'll boot up normally with only the Mains connected to the machine. You can run your laptop only with the Charger connected to it while you are looking for the battery.
If this is not the case, let me know with what you've tried/done so that we will not continue the same.
Good luck.
Awaiting.
Thanks for using FixYa.
Posted on Aug 28, 2010
  • Lebanon Raingam
    Lebanon Raingam Aug 28, 2010
    Ok, then let's first check the Ram (Memory).. Remove the battery, unplug the charger and open the Ram cover (Memory Compartment) and remove the Ram/s. Now power on the Laptop after the power charger is reconnected. What do you see? similar screen as it was with the ram installed? or is there any difference? It would be better and very helpful if you have two rams instead of only one. In this case, reinstall one of them and reboot the system. You also need to clean the ram using an eraser (Pencil Eraser/Rubber). Now reinstall the ram/s and boot the machine again. If it's not successful. Open the back cover and remove the hard disk, now power On the machine without the Hard disk installed but with the Ram installed. Still the same?
    Let me know after you are done.
  • Lebanon Raingam
    Please use the "Add a comment" below my posts. I am confused since there are several experts involved with this question.
    Thanks
Will not function unless plugged into mains, says battery is fully charged
How old is the battery? It may be time to replace it? Always use a genuine replacement.
Apr 29, 2013 | Computers & Internet
BIOS can not recognize HDD
Mother board hard drive controller may be bad requiring replacement of motherboard. Re format hard drive.I would remove hard rive and install it into my external drive module and connect it to another computer then exercise a hard drive repair program.
Dec 14, 2012 | Toshiba Satellite 1900-102...
Computer won't turn on
try removing the battery and see if it runs on mains power, if so you need a new battery. another possibility is that the system has overheated, although you would normally expect it to start up once it has cooled down, unless it has done irrepairable damage!
Mar 08, 2012 | HP Mini 1000 Netbook
It wont switch on
try to remove the battery , then press and hold power button for 8 secs. Then insert the power cable instead of battery. Turn it on. If it wont, try to disengage the power cable and insert the battery. If still wont turn on, kindly inform toshiba about this problem and have them fixed immediately. It is either the battery, the cable or the pc unit itself that causes your laptop failure...
Mar 01, 2011 | Toshiba Satellite C655-S5139 Notebook
I have a Toshiba 32AV600A which randomly scans through all tv chanels by itself, have to turn off and back on to reset, have removed power cord and also reset to factory settings. it also turned on by...
the solution for the problem is to reset the system.the reset button is located on the mainboard PCB..this is the only 1 switch found on the main board just press the switch twice and the system will be reset..to go to the mainboard remove the back cover of your tv and you can see the main board..
tnx hope this helps you.
please rate my help..
Jun 05, 2010 | Toshiba 32AV600E 32 in. TV
Toshiba Satellite P30 (new) Battery (and old) not charging
Your charging circuitry, inside the PC may be faulty. OR maybe the Power Adapter, you need to try another adapter, if the problem does not go away, then you have an internal motherboard power supply problem it will have to be serviced. Or just maybe the second battery is faulty too, unlikely.
Mar 26, 2010 | Toshiba Satellite P30-S701TD Notebook
The PDA turn off and it will turn back on immediately later ......
I get much the same, but it comes and goes. For a week or two it will behave itself, then goes pop for a month or three! Do you find if you have external power (cradle or USB) that it will switch off? I also find that if I switch it off from battery power, it will switch itself back on, but then the power switch is ineffective for 6 or 7 seconds. Then you can switch it off, only to repeat the whole excercise again (and again, and again, and again...)
Sep 08, 2005 | Toshiba e740 Pocket PC
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
