I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
    Genius:
  • 1,224 Answers
Cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
Posted on May 07, 2008
No sound comes out of the system/speakers on my FW-C255/37
There is a problem with the headphone jack or there is a audio output problem, get some electronic contact cleaner attach straw and spray inside the jack, push the headphone jack in and out quickly and spray again and repeat, this should clean the contact points, if no sound, audio output should be suspect.
May 10, 2012 | Philips FWC255 CD Shelf System
Static sound
Try a CD cleaning kit and follow instructions if this fails it is more cost effective to replace the CD changer than have it repaired.
Apr 05, 2012 | Sony CDP-CE275 5-Disc CD Changer
I got a premier, pioneer DEH-P200 sterio and ive hooked it up to my 92 chevy truck and my 94 camero but in both it powers on. and beeps through the cd player for volume changes and stuff like that but its...
WELL THIS RADIO CD PLAYER WILL NOT WORK WITHOUT AN AMP HOOK UP IT JUST SENDS A SIGNAL TO THE AMP AND THEN TO THE SPEAKERS. YOU MAY HAVE TO FIND THE AMP THAT DIRECTLY HOOKS TO THIS UNIT...
Jul 15, 2011 | Pioneer DEH-P200 CD Changer
Can mp3,ipod connect to philips FW-R7 with cd
All you need to get them to play is a "dock" and a 3.5mm Jack to two RCA phono plugs lead.
The Jack goes into the headphone output and the RCA's go into any spare socket on the back of the unit IE tape/cd.
Infact you just need the lead, plug it into the headphone output of the Ipod or MP3 player. But the dock will keep the battery charged and you get a remote with the dock, so you don't need to get out of your chair, to operate the player.
Feb 08, 2010 | Philips FW-R7 CD Shelf System
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
Jul 17, 2009 | Philips FW-R7 CD Shelf System
Shelf system shuts after a few minutes philips FW-R7
In power supply check capacitors ,one of them is leake or dry.Best way of detecting this cap is to have freez it (coolant) to sprey on the sections in power supply and thanindividual capacitors this will definately solve your problem.
Dec 16, 2007 | Philips FW-R7 CD Shelf System
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
My actually have a Philips FW C775
Yanking a magazine out while it is in operation is a recipe for disaster. Probably a disc has gotten jammed in transit, preventing removal of the magazine. You probably will have to disassemble the Philips player enough to get access to the area where the CD is jammed, gently guide it into the magazine, then remove the loaded magazine.
Jun 13, 2017 | Philips CDC775 5-Disc CD Changer
124 people viewed this question
 Grubhead
Grubhead
