Question about Sharp UX B700 Plain Paper Inkjet Fax
Can not fax any document
In the begining I could fax any documents and then suddenly The fax
machine did not want to fax nothing.Every time I want to fax it prints
the report and say line error x-2.I checked phone line connection
and everything is ok like it was before and then I tried to fax it
from another phone line and it is still same (line error).What could this be?
Can anyone help me with this?
Thanks,
Lilliana
    Problem Solver:
  • 16 Answers
When machine clear this problem may be solved, First you make setting as i said to machine. Press buttons respectively as i written function 9 * 8 # 7 then start button , it gives DIAG MODE then press satrt, With the help of star button go to memory clear and press start key. machine cleared memory, gives printing of MEMORY CLEARED. this setting will solved your problem.
Posted on May 07, 2008
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
When recevie fax their is nothing document but error code coming 242
This link covers all error codes. http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#Error232
Error Code: 242 Definition
The remote fax machine is attempting to receive instead of send. Both machines have attempted to start a reception at the same time. On many fax machines, it is possible to accidentally initiate a fax reception in the following cases:
  • There is no paper in the machine.
  • The paper is not correctly loaded and the document sensor cannot sense it.
Solution
Contact the sender to make sure that a document is ready and correctly loaded in the sending fax machine. Also make sure that the remote machine is attempting to initiate a transmission and not a reception.
Feb 28, 2011 | HP Computers & Internet
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Lines on fax going out, fine receiving fax
check the scanner glass under the cover where the documents are fedd through if you lift the lid on this you should see a thin slip of glass if this has ink or usually tipex on it the lines will be on every fax that goes out.. there might be a small roller over this that has a clip each end you can take this out for acces to hte glass
Jul 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Printing all document out the back of machine
There is a lever in the back, lift it will divert the papers to the front again. ( looks like a small door)
Dec 09, 2008 | Brother IntelliFax-4100e Fax
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
I have an hp laserjet 3050 fax machine. When I go to fax several documents at one time, the fax grabs the whole stack and sucks them through. How can I fix this problem?
The first step is to insure that the top cover on the Automatic Document Feeder is closing properly. If it is not, the pages may multiple feed. If that is fine, then there is a pad that separates one page from the next in the ADF assembly. It wears out over time and begins to let the pages multiple feed. The part is normally replaced with the feed roller in the ADF at the same time. These are usually changed by a technician. The part #'s are RM1-0890 for the pad and RM1-0885 for the roller, you should be able to order them online.
Hope this helps!
May 15, 2008 | HP Office Equipment & Supplies
Sharp UX B700 Plain Paper Inkjet Fax Logo
127 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
