Question about Sport & Outdoor - Others
Proform elliptical cardio crosstrainer 820 has lost resistance
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Posted on Mar 03, 2010
  • 3 Answers
SOURCE: Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Posted on Jun 19, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jul 16, 2010
ercupa190
  • 12223 Answers
SOURCE: ProForm 675 elliptical is very hard to peddle
use the next steps:
Step 1
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed switch. These elements will be roughly the same size, and the reed switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed switch using your screwdriver. Move the reed switch by hand until it sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the display and heart rate monitor are working properly. If not, move the reed switch slightly so it is closer or farther from the magnet, then try the machine again. Once you've found the correct location for the switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
8_1_2012_1_02_58_pm.gifGod bless you
Posted on Aug 01, 2012
What is the power source for the display console of a proform 650 cardio crosstrainer elliptical? The display on mine is not on.
you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manual
God bless you
Nov 01, 2013 | Proform 650 Crosstrainer Treadmill
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
A friend recently gave me a ProForm 700 treadmill that folds up & the front left side of what appears to be the belt or possibly the rotor sounds like dolphins talking when you turn it on. How can I...
dEAR Sir:
I will help you inmediately.
HOW TO LEVEL THE ELLIPTICAL CROSSTRAINER:
After the elliptical
crosstrainer has
been moved to
the location
where it will be
used, make sure
that the ends of
both stabilizers
are touching the
floor. If the elliptical
crosstrainer
rocks slightly during use, turn one or both of the leveling
feet under the front stabilizer until the rocking
motion is eliminated.
2) You must put a little oil ( tree in one oil) +a little grease in the rotor shaft.
Hoping that you fix this, anyway if you need some extra help, contact me.sincerely.
blessing.
E.CUADRA
Managua, Nicaragua C.A.
Sep 13, 2011 | Proform CrossWalk TreadSoft Treadmill
I have a Pro-form 650 Cardio CrossTrainer. All of the information on the display is displayed correctly but the resistance seems to be too high on level 1 and the resistance knob is difficult to turn once...
Normailly there are 2 system:
1) Manual, see the belt if there are defective,try to put a Little LUBE it,since has a LOT of mechanical stress. Replace it if Necessary.
2) The small motor in the system, can be faulty or broken, replace it.However test the batteries if the system have, clean the contacts batterys, with special liquid clean contacts cleaner, and tight very well the connector, and clean too.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 28, 2017 | Proform 650 Crosstrainer Treadmill
I have a proform 390E, and it has a resistance problem, I just checked all the wires and they are connected properly, what should I do now?
Have a 390E elliptical. riding on resistance 4 and then it shut off and went back to resistance 1. now it will not accept any resistance, if you punch in 2 or 3 it registers and then drops back to 1. battery problem? help
Apr 29, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Dec 31, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
I need owner's manual for proform 900 cardio cross trainer
go to www.iconfitness.com and follow the instructions. You can do everything from that site. We are service dealer for them, and we like to help..
Aug 10, 2009 | Proform 675 Crosstrainer Treadmill
Sport & Outdoor - Others Logo
275 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
