I have just bought a hp wireless laptop but my thomson router does not come up in the list to connect to , belkin and others do, how do i add thomson to the list
  • 30 Answers
Assuming that a thomson router is a wireless device and not a DSL or cable modem then check the router settings under 192.168.x.1 where x is usually listed on the back of the device and see if wireless broadcast is turned off. check you have the right wep/wpa/wpa2 settings turned on and that mac access control is turned off until you've added this new device successfully. Also check that you're not trying to use a wireless g device with a wireless b router config - ensure the broadcast and device compatibility stacks up.
Posted on Aug 28, 2010
How can i install my wireless router to other laptop?
The same as 1st laptop.
1. Locate the wireless-network-connections option
on your computer or wireless device.
2. Select your Belkin Router from the list of available networks. You
can identify your Belkin Router by locating the network name
(SSID) from the card located underneath the foot of your Router.
3. Enter your network password (located on
your network information card).
Oct 06, 2012 | Belkin Connect N150 Wireless N Router
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
Click Here for step by step instructions
Dec 27, 2009 | Belkin (F5D7231-4) Wireless Router
N1 Belkin to HP notebook - connection speed drops to 24mbps
It might be because of other electronic devices that works nearby in similar frequency...devices lik microwave oven, inverters, modems provided by the ISP which comes along with a battery backup, especially RCA modem which doesnt allows other wireless devices to work nearby it... try to relocate the router to a well ventilated area, and make sure you have kept the router atleast 5 feet away from other electronic devices...it could help....
Jun 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Cannot connect to wireless printer, pc is connected to 54g direct
its a bit complicated but we can try out.find out the ip address of teh wireless router,,put it in the address bar and click entera box will com for a username and a passwrd.if u havnt chaged anything.then default username and passwrd is{Belkin
IP : 192.168.2.1
username : admin
Password : (Blank)
try this and u will see a belkin page,,search for connected devices and u will see the printer option there.in the mean time install the drivers of the wireless printers on the desktop pc,,follow the prompts on the installation very carefully,,its easy and then make ita s a default printer,thats it
Feb 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect Belkin F5D8233-4 Router to Mac Laptop
If you tell me the version number of your Belkin wireless router , i can fix this issue.Any Routers issue contact me,, i can help you out. copy and paste this address to Browse,Mentioned below http://techhobbies.blogspot.com
Jan 26, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless connectivity
You probably set an access list on your router
connect to Router using a LAN cable and check if you can browse.
Then
Check your access list on router.
Disable it if you cannot add your PC wireless adapter MAC address
Jan 04, 2009 | Computers & Internet
Belkin (F5D7050) 802.11a/g/b Wireless Adapter, home networking. I am on AOl using Thomson speedtouch, I am trying to link up 2 pc's and one laptop to access the net. Main Pc is Vista - with wireless...
try to reset the wireless router to factory default.( with out encryption). connected the Xp first. then the other two.
try to use simple encryption (8 characters).
Oct 12, 2008 | Belkin Computers & Internet
Connection problem
don't shout at me, but many of the older compaq laptops did not come with a wireless nic installed, and the ones that did sometimes did not support G let alone N.
If able you need to check that the Wireless NIC if installed/avaliable supports your wireless router or most likly the otherway round.
firstly I would try removing any USB wireless adapters that you may have in use from one of your other computers and try it in the compaq, if sucessful you know that it is not your setup of your home network at fault.
Sep 02, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
