Question about Ovens
I have a mer6770acw matag doubleoven.there are 2 codes coming up f1-1 and f3-1.i have installed a new oven sensor and have used the oven for a few times and now this is happening again.could you tell me what the problem is.
  • 10,515 Answers
F1-1 Runaway cook upper oven
F3-1 -
Sensor upper oven
Both indicate faulty oven temperature sensor. If you have experience in these appliances, replace the sensor and it would be all set.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 28, 2010
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
MAYTAG OVEN ERROR CODE F3
Hi Janine.
F3 means "Shorted oven temperature sensor" and it is returned when the oven electronic control detects a wrong impedance value from the oven temperature sensor circuit.
The oven temperature sensor is a probe located inside the oven cavity. The sensor can be removed from the oven and tested using a multimeter set on impedance. The impedance reading across the two sensor's contacts at room temperature must be about 1100 Ohms. Impedance increment rate is 100 Ohms more for every 50 degrees temperature increase. If the reading is sensibly different from this value the sensor must be replaced.
Here the replacement part:
Long Oven Sensor Kit
The sensor is indicated as part number 11 in the exploded view available here.
The sensor is held by two screws. In order to replace the sensor disconnect power, disconnect the connector attached to the sensor, undo the two screws and remove the sensor. Perform operations in reverse order to install the new sensor.
Regards.
Ginko
Jan 15, 2012 | Maytag Ovens
I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
Jan 12, 2012 | Ovens
GE OVEN THROWS F2 AND F3 CODES SOME TIMES WORKS FOR 45 MINUTES BEFORE CODE
The F2 code means that the oven overheated by at least 100degrees(a bad sensor will cause that)
the F3 means that the oven sensor is shorted,so both of them are consistiant with defective oven tempature sensor and the sensor should be replaced.
It is located in the oven baking chamber and can be replaced by unscrewing the screws from the bracket at the end of,pull it out unplug it,then reverse that process to install the new one.
With 2 different codes pointing to a bad sensor its apretty safe bets its bad.
GENE
Oct 10, 2011 | Ovens
I turned on my oven to 350. It heats up to that temperature, but a few minutes F 3 comes on the info panel.
Hello Lynn,
The F3 error code means the oven tempature sensor has became defictive and needs to be replaced. You can clear the code buy pushing the stop/clear button,and try to use the oven again if no code all is well,if the F3 code does return the sensor should defiently be replaced.
This is what the oven sensor looks like.
to test it before replacing use multimeter set to ohms and at room tempature the display on the meter should be between 1060-1100 ohms when placing the meter leads on the two wires inside the sensor plug,if the ohms are considirely more or way than 1060-1100 replace the sensor.
The part number for the sensor is WB21X5301 it could be purchased at your local appliance parts store on online at;
searspartsdirect.com
apwagner.com
apdepot.com
repairclinic.com
Aug 20, 2011 | GE Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 | Ovens
Kenmore electric range F5 and F3 warnings
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 13, 2008 | Kenmore 30169 Electric Single Oven
Oven turns off F3 flashes
Bob, an F3 error code denotes a failed oven temp sensor. See below.
F3 Open oven temperature sensor circuit Replace oven temperature sensor
The repair is pretty straight forward, but you should have the replacement part in hand before you begin. The part number is WB21X5301 and retails for about $95.00. I just found one online for $72.60!
The sensor is located inside the oven cavity mounted to the top of the rear wall. Remove the 2 screws and slide it out of there. The sensor has a plastic connector connecting it to the main harness behind the oven. Pull this carefully through the hole. If you can't get the plastic connector through, then you'll have to pull the oven and do this from the back... alot more work but still do-able. Simply disconnect the old sensor from the plastic connector and install the new one. Then feed the wires back into the oven and re-mount the new sensor.
If you don't have to pull the oven, the job should take about 20 minutes and all you need is a 1/4" nut-driver or socket.
If you have to pull the oven, re-post and let me know... I'll walk you through it.
There ya go!
Aug 22, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
