Question about Archos 605 WiFi Digital Media Player
I have an archos 5 250GB model 6500 and my problem is that when I try to turn it on it goes to the start up archos page and thats it. It doesnt go to the menu page and after a while it turns off. I tried to reset it and that doesnt work. It is fully charged but I dont know what the problem is. How can I fix it?
SOURCE: 605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Posted on Nov 17, 2008
ArcSup
  • 5 Answers
SOURCE: recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
  • 6 Answers
SOURCE: first time charging up of archos 5,it has now been
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Posted on Mar 13, 2010
  • 161 Answers
SOURCE: Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Posted on Apr 13, 2010
Thompsons196
  • 350 Answers
SOURCE: Who can replace my Archos 5 IMT 250gb battery?
I don't really know about this but my MP3 battery went out I took it apart cut the battery the was in it solderd a new one. If your don't want to do that take to a repaire tech in the phone book.
Posted on Jan 27, 2011
I recently purchased an Archos 101 tablet and after turning it off about a week ago, it didn't turn back on and I have tried everything I could think of ever since. The light on the side of the unit is...
At this point you'll want to return or RMA the unit to Archos for repair/replacement. You can find information on how to do this on their homepage.
Feb 04, 2011 | Archos 101 Tablet PC
I have an Archos 5 250 Gb Model 6500 (pre Internet Tablet) and I was wondering if you know how to disassemble it so I can replace the battery.
Disassembling Archos will void device's manufacture warranty. You should not do it yourself. There is some parts are very fragile will cause a permanent damage to the device. I will not recommend for you to do it yourself.
Jan 17, 2011 | Archos Internet Media Tablet MP3 Player
Archos 5 won't boot up
im having the same problem,people say reset it and put it into recovery mode (it tells you in the quick start guide) or that didnt work for me so im trying charging it up fully.  also mine makes a noise while trying to turn on, are you having this problem to?
Jun 28, 2009 | Archos AV 500 Digital Media Player
After formatting the archos5 ,the device doesnt get recognised
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up, just pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 16, 2009 | Archos 605 WiFi Digital Media Player
Getting a white screen with 102 error message
* When the white option screen comes up pick the format disk
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
My archos 5 wont switch on to the home page
You should perform this when it is on
problem solve #1
* Press the reset button on the buttom of the device using a papr clip. It should shut it off. then try to turn it on again.
try the next if the problem still exist.
Problem solve 2
* Download the latest frimware from Archos.com on to the desktop on your computer ( i recommend desktop because it will be easy to find) Then plug the device to a pc Using USB cable. turn the archos on by holding power switch and TV/LCD buttons at the same time until a white screen comes up. it should ask for Usb. if it does pick the ubs. if it does not give you a USB option but these "NO", "REPAIRE", "FORMAT" move the curser to repaire. do not pick the format which will delete all the contents and plugins you have on your device.
after repaire completes it should say done. do not press the done wait until you see the archos connection under My computer. it should normaly come up with name 504 or you will be able to see the archos icon. place the firmware in to the main drirector not under any folder. then press the ok button to confirm the "done" device will power off and start with a white screen again but this time it will update the firmware and restart do not unplug the Usb cable until the update completes. It should restart again and load the normal user interface. Your device should be fine and back to normal.
Jan 03, 2009 | Archos 504 500870 Digital Media Player
Archos 404 camcorder
sound like you may need a new battery. look on the archos FAQ page to see if that is what it is. if so you can do this two ways you can fit the battery your self, you can buy the battery from newmp3technology.com or type archos.co.uk. or you can send it to the archos repair by calling 0870 609 1693 this will put you to the archos uk repair team
Jun 18, 2008 | Archos 404 Digital Media Player
Pi would like to get my player back,pls...
hi!
go to archos.com click on downloads then click on firmware and follow the instuctions !! =].. i had the same problem!! all my music got deleted but it works again !!!
Feb 29, 2008 | Archos 405 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
290 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
