Question about Cobra HH 38 WX 40-Channels Handheld CB Radio
Cobra 38 WXST Handheld - Which is positive on DC connector?
I am going to make a DC cord to plug into the cigar lighter in the car. I need to know if the inside pin is positive or negative.
    Brigadier General:
  • 6,966 Answers
To my knowledge, it is positive. To confirm, pls look closely at the markings beneath the DC power jack.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 07, 2008
Ciger lighter position 41 keeps blowing 47 ok
AUX PWR Fuse #41
20A
Auxiliary Power Outlets - this not Cigar lighter ,the power outlet is bad. replace it or short to ground in wiring.
CIGAR Fuse #47
15A
Data Link Connector, Cigar Lighter
the power
Nov 08, 2015 | 2000 Chevrolet Silverado
Cobra xrs 9955
The simplest advice is to check the power connections. If connected to the cigar lighter / power outlet of the car, remove & reinsert the plug into the outlet.
Still no luck?
Try powering up the detector in another vehicle's cigar lighter / power jack. If it works - try again in your car. The problem is not with the detector, but rather with the installation in your car.
If wired directly to an accessory terminal or other place in the car, check the connection(s) and cable for damage.
If you can't try it in another car, try plugging another device into the outlet to see if it works or check and replace any blown fuse for the outlet. You should consult your car's owner's manual for the fuse box location - and the location and amp rating of the fuse for the outlet.
Check the power cord. Make sure the cord is fully inserted into the detector - not hanging in the jack. The opposite end - that goes into the cigar lighter / power outlet *may* have a built in fuse in the tip. You should check to see if the center tip of the plug unscrews to provide access to the fuse. If it does, replace any blown fuse with the same type and amp rating and try again.
If you were unable to check in another car and you are still unable to power up the detector, there may be an internal problem with detector itself. In this case, contact the manufacturer for additional help.
Jun 06, 2013 | Vehicle Parts & Accessories
When docking the headset cobra road trip and activate the ptt who hear me get a ring
  • Hi, I can help. When the microphone/earphone set is inserted in the radio itself the control is automatically turned over to the headset. There are no radio adjustment that need to be done. Just plug it in and use the PTT on the cord of the headset or unplug and use the controls on the radio itself.
  • Many don't know that the Cobra Road Trip and the Cobra HH 38WXST are identical radios. The only difference is the antenna sold with the two radios. The one you have come with a rubber duck style antenna and the HH38 WXST comes with a magnetic car mount antenna. So while the manualfor the Road Trip is hard to find the 38 WXST is not. Here is a copy of the manual http://minus.com/mTQOgU0yw
  • Read through the manual a couple times and feel free to get back to me with any questions you have.
  • Hope this helps.
Oct 28, 2011 | Cobra Road Trip 40-Channels Handheld CB...
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
I need a cigarette lighter power cord for a Uniden LRD2400SW radar detector.
go to radio shack.they have sell a universal cigatrette lighter make sure the dc voltage rating.
Feb 12, 2010 | Vehicle Parts & Accessories
Cobra 75 wx st fuse keeps blowing. As soon as I plug the transceiver into the connector box the fuse blows.
Hi and welcome to FixYa,
Initially, check the reverse protection diode, D18 (1N4004). It would be located / connected at the power board of the DC connector.
Good luck and thank you for asking FixYa.
Oct 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
My Cobra Road Trip handheld CB won't switch over to battery power when I unplug the 12v adapter. How do I open the casing to check if the spring behind the connector can be repaired or replaced?
Make sure you have good batteries in it ,and installed correct. There should be a switch behind the battery,i think.... but there is a switch on it for ac or dc,switch it to dc,make sure you have the ac plug adapter end unpluged from it in order for it to work......hope this helps.....
Jun 28, 2009 | Cobra HH 38 WX ST CB Radio
The voltage for charging and plug-in power, cobra hh35?
the voltage for the charging is 12 volts dc the charger is a 110 volt dc 12 volt to the radio if you lost your charger you can get a aftermarket at any radio shack store just be sure you take the walkie with you when you go so they can match up the rdio plug end.
Mar 11, 2009 | Cobra HH 38 WX 40-Channels Handheld CB...
Cobra Cb handheld radio model: HH-35 doesn't work
Open up the back of the radio and check the solder joint from the antenna connector. I had same problem and it was this.
Mar 23, 2008 | Cobra HH 38 WX 40-Channels Handheld CB...
Cobra HH 38 WX 40-Channels Handheld CB Radio Logo
153 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
