Question about Refrigerators
Fridgidaire top and bottom both blowing warm air '
  • kathykatkev Apr 27, 2009
    My fridge is blowing semi warm air out of both freezer and fridge..Everyone is telling me the condensor and/or fan needs to be cleaned...only problem i don't know where the condensor or fan is and my owners manual doesn't say..I have had it for a little over 10 years ....my model # is MRT18DNEZO ...thanks
    My fridge/freezer is blowing semi warm air.....I know the condensor or the fan needs to be cleaned...I just can't find the condensor or fan on my model....my owners manual says the same thing but doesn't show where eithier is.....my model # is MRT18DNEZO..thanks
  • 828 Answers
A model number would be of assistance in trouble shooting your problem. Check the condenser and make sure it is clean and the fan motor runs when the compressor runs. If the compressor gets overheated it will cycle off on its thermal protector. Allow time for it to cool off before restarting it. You did not give the age of the refrigerator. If it has a lot of years of runtime on it the compressor may be done working.
Posted on May 07, 2008
We have got water coming out at the bottom of the freezer of our fridgidair FRC170FF how do i fix it?
1. Your freezer may be not cold enough so water does not freeze.
2. Your freezer may leak so warm air goes into the freezer and keep the temperature higher than freezing temperature.
Jul 03, 2014 | Miele KFN8762SDED Bottom Freezer...
In cold weather heater will not blow warm air unless at idle stopped. when at highway speed blows cold air
check and make sure the radiator is full of antifreeze take off the radiator cap and top off the radiator then take your hand and cover the hole where the cap goes and squeeze the top radiator hose a few times to help it go down that way if there is a air pocket somewhere it will help push it out when you thank your done top off again and replace the cap and try
Jan 27, 2014 | 2003 Ford Focus
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
My heater blowing cool air want blow warm or hot air
check top and bottom hose for heat if the top hose hot and bottom hose cold the thermostats not opening,or you may have a leak from a hose or water pump, maybe only a small leak but that would cause the system to lose pressure and lose heat from your heater at worst the head gasket may have blown
Feb 09, 2011 | 1997 Honda Civic
Ice maker is le
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Good luck......
Aug 01, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Heater blows cold air from top vents after running for 1.3 hours
Sounds like you may be able to fix it by flushing your antifreeze and back flushing the heater core. Some car owners cheep out and put stop leak into the antifreeze, others dont change there antifreeze at all. Both are mistakes.
Mar 05, 2009 | 1990 Chevrolet Lumina
Fridgidaire refrigerator freezing
close the baffle that blows air onto the top shelf a bit.
Or you have a bad thermostat or thermistor- if it's a didital type temp cuicuit
Oct 25, 2007 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
