Question about Sceptre X7GNAGAV 17" LCD Monitor
Sceptre monitor 15". On start up screen displays 'key lock'. Can not change use key functions including power. How can I take it off lock? Many thanks, Matt
TechButton
  • 7 Answers
SOURCE: Sceptre DCLCD19+ MONITOR WHITE SCREEN
To me it sounds like the bulb is having a problem with powering up. It may be an issue with the power adaptor or the outlet it is plugged into. Have you tried to plug it in, in other outlets?
Posted on Dec 20, 2007
SOURCE: Connecting second monitor
Not sure If I am understanding this correctly, you are trying to connect a monitor to a monitor? I have never heard of that before. As far as I know you need a video card that has dual output to use dual monitors. I am not saying you can't do what I think you are saying but I never heard of that before. Also on a side note depending on the resolution and amount of colors your operating system is set on, you need a video card strong enough to drive both monitors.
Posted on Jun 10, 2008
bunnydawg
  • 5158 Answers
SOURCE: BLANK SCREEN
was she playing with the keyboard. ??
She/he may have shut off the monitor from the keyboard. look for a little picture of the monitor.
Sometimes you need to hit fn (function) key and the display key to toggle it on
Robert
Posted on Aug 29, 2008
SOURCE: Sceptre X9G Komodo IV
I have a 19" Sceptre Comodo display. After 3 years it got the problem everybody complains about. Took it apart yesterday.
There are 4 capacitors in a row on the power supply board (it has a socket for the power cord and is covered by a metal shield. The caps are barrel-like things standing upright on the side opposite to the power cord socket.) Two of them are 470 uFx 25 V, they are next to each other. In my case, one of them popped up and another one was bloated. I pulled out the power supply board (make sure you unplug the power cord and press the power button do discharge the high voltage caps before messing with your monitor) after disconnecting all sockets (mark'em!). I assume that you have new caps handy (I paid $2.10 for a pair at a local electronics store), they must have the same capacity and voltage rating. Now grab a soldering iron, remove old caps, and put new ones in. You must observe polarity! (Usually "minus" pin is labeled on the cap's side. Mark down "minus" and "plus" pins location of old caps and put the new caps in exactly the same way! Otherwise, you can blow the caps.) If you are not used to work with a soldering iron, hire somebody or buy a new monitor. Check the quality of the work (no shorts, solid contacts, etc), assemble the monitor back and may be it will work (did for me). If it does, you put one monitor less into the city dumpster, be proud to get a working monitor for less than $5, and force you mother-in-law to take this shiny new replacement display she just bought back to the store.
Of course I do not guarantee that my procedure will work for and you can use it at your own risk only (i.e. I am not liable for any damages).
Posted on Sep 09, 2008
SOURCE: sceptre LCD - no display
I did sent it to them for the $135.got it back and it works.If it happens again I will slam them like I did roto zip.I got another motor from them but it was a piece of junk too.
Posted on Sep 21, 2008
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
I have purchased an AOC 22" monitor to connect to my laptop >>>>>i have connected it but it does not display. What is wrong.
Depending on the laptop. Most have a key on the keyboard to toggle external display. Usually, you have to hold the function key [FN] then push the external display toggle.
Feb 23, 2010 | Computers & Internet
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Microtek monitor 997m
Try pressing and holding the menu Key for 15 seconds, that is how masy OSDs lock and unlock
Jul 01, 2009 | Computers & Internet
I have a Sceptre x22 gamer that has been serving me well for about two years. A week ago I started having trouble getting the monitor to ''Wake Up'' after the computer goes to sleep or when rebooting. It...
warcryofjuda, One of the guys that I work with brought in a small screen Sceptre DTV/DVI/VGA +audio unit. and it also has a optional TV/tuner module. mod S1701DTV with side mounted speakers. The viewable screen size is 14"w x 8.75"h . Oh! First things first! Turn it OFF and leave it off. Disconnect it and put it in a safe place for now. IT'S BROKE!! It will not work today, and it will not work tomorrow or the next day. Got that? Ok! Now I want to know if you would like to work together with me and explore both of these monitors and possibly come up with a fix for them? Please get back to me via my email with what ever approach you feel is best for you. We have already opened up our unit and I will try to attach some pic's for you to compare your unit with. I'm louie12fix on fixya or lmistyrel@aol.com
Bye for now.
Apr 15, 2009 | Sceptre x22wg Gamer Monitor
Sceptre LCD - no display
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
BLANK SCREEN
Robert
May 08, 2008 | Sceptre S1902D-4 Monitor
Dec 20, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor display problem
there is a problem in the vertical , change the ic please
Dec 17, 2007 | Philips SoHo 105E 15" CRT Monitor
Sceptre X7GNAGAV 17" LCD Monitor Logo
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
