Question about Mitsubishi VS-5076 50" Rear Projection Television
My Mitsubishi Model VS-5076 will not turn on. We recently lost power in an during a storm, then when the power came back on the TV didn't. When it's plugged into the wall the green Power indicator on the front of the TV is on so I know it's getting power. However, when I hit the Power button on the front of the TV, or when I hit the power button on the remote, the set refuses to come on. Is there some type of reset I need to perform?
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Posted on Dec 11, 2007
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
  • 1153 Answers
SOURCE: 50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Posted on Mar 17, 2008
screentv
  • 22 Answers
SOURCE: replacement screens
try www.tvscreenprotectors.com
Posted on Jun 15, 2008
screentv
  • 22 Answers
SOURCE: Need Replacement Screens Mitsubishi VS- 5076
try contacting www.tvscreenprotectors.com for discontinued replacement screens
Lost inputs 1,2 and 3
try reseting the tv to manufacture settings in the
menu,or unplug it and try a different outlet,it works sometimes
May 09, 2009 | Mitsubishi VS-60603 60" Rear Projection...
TROUBLE SHOOTING TV
youve lost your power supply there is no reset for your model tv.
Jul 13, 2008 | Mitsubishi VS-5043 50" Rear Projection...
I have a Mitsubishi VS-5004R and it goes to a black screen but the sound still plays. If I leave it unplugged for a while it will come back on but goes out after 20 or 30 minutes. What could be the...
Bad capacitors made by Rubicon in many power circuits......
pull chassis...look for over-heated areas for repair in horiz,vert.
and power supply,check any / all caps with ESR meter.....T.
Mar 19, 2008 | Mitsubishi VS-5076 50" Rear Projection...
Mar 17, 2008 | Televison & Video
Mitsubishi VS-60707 60" Rear Projection TV
1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET
Aug 21, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
