Question about GPX MW3337G
Won't sync or turn on
I just bought this today. It says that there is 0 percent battery power. It won't turn on, and it won't sync. This is the new one with a Li-polymer rechargeable battery
    Genius:
  • 1,224 Answers
Well with everything a person buys that has built in rechargeble batteries in them you have to charge first before you can really do anything with new products charge first if that does not work take back and exchange cause of defect
Posted on May 07, 2008
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
My rino won't charge
Two things occur to me: possible damage to socket where charger connects to unit------or no voltage from charge source to the battery
A lot of the connectors where the unit connects to power are easily damaged.
Nov 03, 2012 | Garmin Rino 530 GPS Receiver
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
I have phillips 42pf9631d/37 that wont turn on and blinks red seven times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 25, 2011 | Philips 42PF9631D 42 in. Plasma Television
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Starter shorts when turning key from "on" to
Check all ground wires and make sure they are tight. Start at the battery, starter, solenoid switch.
Dec 15, 2017 | 2005 Scion xA
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
GPX MW3337G Logo
24 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
