Question about Lexmark Wheelwriter 30 Series II Typewriter
My IBM Wheelwriter III does not print the letters. I have replaced the ribbon but still no letters. Please help. Thanks.
  • Lexmark Master
  • 3,594 Answers
The print solenoid plunger has a plastic cap it is probably broken. They are available but a little tricky to jnstall.
DickyO
Posted on May 13, 2008
    Genius:
  • 1,224 Answers
Rub your finger over the ribbon if no ink on fingers then your ribbon is dry little solution for old ribbons is cotton and little water over ribbon not too much
Posted on May 07, 2008
Ribbon will work in one Wheelwriter 6, no print output in another one
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Jan 16, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less...
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
May 21, 2011 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 5
yes it was true that the cap was broken. temporarily, i just cut a piece of plastic from a spoon, same thickness as the cap then place it between the plunger and the solenoid. and now my wheelwriter is typing great! all letters are clear and much black in color. thanks for pointing where the cap was place. easy to find it.
Apr 01, 2009 | IBM Office Equipment & Supplies
IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter III
gotta clean the wheel off with old ink sometimes this can be a problem but the ribbon might not be seated properly
May 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Mar 20, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 30 Series II Typewriter Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
