Question about Dryers
HI, tHERE IS POWER ALL THE WAY THROUGH TO THE SWITCH, DOOR CLOSED AND DRYER WILL NOT START?
    Problem Solver:
  • 6 Answers
Check stater capasitor with a blown cap you should hear the motor hum if not check motor, on switch some dryers have a fuseable link
Posted on Aug 28, 2010
Amana Dryer Model # NED4500VQO won't start
see the following steps and fix it. God bless you
. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-1#ixzz2Yb4M1zkU
Jul 09, 2013 | Dryers
Kenmore 97478100 dryer will not start (not a heating issue)
HI, check the following to address this issue.
1. No power to the dryer
The dryer will not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Oct 08, 2009 | Kenmore Dryers
Dryer doesn't start
3. Thermal fuse
Oct 04, 2009 | GE Dryers
Dryer will not start, worked all day, changed loads, and would no longer start
3. Thermal fuse
4. Timer
Sep 05, 2009 | Dryers
Dryer will not start when button is pushed. Maytag model # DE 610
3. Thermal fuse
4. Timer
Aug 18, 2009 | Dryers
It will not start. We checked the plug and the circuit breakers and it will not start in any cycle
3. Thermal fuse
4. Timer
Jul 25, 2009 | Dryers
Whirlpool electric dryer (Model # LER4634DQO). Dryer won't come on when we push the start button.
3. Thermal fuse
4. Timer
Jul 08, 2009 | Whirlpool Dryers
Won't start - 3 beeps when Start button pushed
CHECK THE FOLLOWING--
May 31, 2009 | Kenmore Dryers
Stoped working
May 30, 2009 | Miele Dryers
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
20 people viewed this question
Top Dryers Experts
