FixYa.com
Tags:
IBM Wheelwriter 30 Typewriter
IBM Wheelwriter III
posted by lebamm on May 07, 2008
My IBM Wheelwriter 3 does not print. Changed ribbons but no result.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 12, 2008
Not Rated (0)
DickyO
Rank:Guru Guru
Rating: 89%, 142 votes
Try typing on a milti part form or a carbon if the carbons are OK it is a ribbon problem if not you probably need a print solenoid cap. If the carbons are OK the big black plastic gear may be jammed tooth for tooth with the motot gear try wiggling it back and forth.
DickyO
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 07, 2008
Not Rated (0)
shaggyrat
Rank:Wiz Wiz
Rating: 82%, 434 votes
gotta clean the wheel off with old ink sometimes this can be a problem but the ribbon might not be seated properly
Can you Help with these Typewriters problems?
Typewriters
Ribbon issue
The ribbon will not advance on... Answer This...
Typewriters
Olivetti Lettera 32 - carriage...
I've just bought a Lettera 32,... Answer This...
dominican accountant...
dominican accountant... Answer This...
desk top icons
I was cleaning up my desktop... Answer This...
We have an AT&T...
We have an AT&T... Answer This...
Repair Service
Find Typewriter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
