Question about Miele Novotronic T240 Electric Dryer
How do you clean the miele 240 tumble dryer? The red light keeps coming up stating clean the airways and i cant find my manual
  • 1122 Answers
SOURCE: my hotpoint vtd65 tumble dryer
unplug and wait a few minutes and see if it resets itself,mike
Posted on Sep 13, 2008
Obertelli
  • 3006 Answers
SOURCE: My dryer cuts out after a very short time and the
The filters may be clear but is the exhaust blocked or obstructed in any way? If there's an exhaust hose then also check that it's not been crushed or restricted by any sharp kinks in it's run.
Something is certainly causing an airflow problem as it's causing the machine to overheat and cut out.
I'm unfamiliar with your exact model, but I've found that some dryer designs are also prone to getting a restrictive build up of dust or lint in places the designers never envisaged and to clear those kinds of blockages I've successfully used vacuum cleaners set to blow or **** as needed and in the worst cases have needed to partially dismantle a machine to clear out the obstruction: you'll be surprised what can end up inside if you have children or pets...
Posted on Oct 07, 2009
Testimonial: "Thank you"
rogrrabbit
  • 986 Answers
SOURCE: Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: miele novotronic T640 about 9/10
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hello - I have a
1...You may have more than one problem on your problem with your dryer not heating.
2...Your noise (ba-ba-dum) is being made by your drum rollers that probably have flat spots on them and is in need of being changed.
I will include two solutions to your two problems, I am not sure if the disassembly of the dryer that I am going to send if for will be applicable to your dryer disassembly but it may help
-----------------------------------------------------------------------------------------------------------------------------------------------Problem 1...Not heating
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Problem 2...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Dec 29, 2010
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
Miele tumble dryer Novotronic T430 door keeps popping open why
Clean all filters on machine this will sort the problem out .
Jun 29, 2014 | Miele Dryers
Reset the thermostat
If the dryer has dryness sensor strips they may have a coating on them repelling moisture from wet clothes. The brains might think them clothes is dry. Clean the sensors with windex and party on.
MIELE NOTES FROM FOGGY
Jan 03, 2014 | Miele T8000 Series : T8005 24 Electric...
The machine keeps saying clean out airways yet there is no fluffy stuff on the filters i have hoovered them out as well
Remove all 3 filters, half moon filters below door, filter in door and heat exchanger from front of appliance and rinse under warm water dry and refit.
Nov 17, 2009 | Miele Novotronic T230C Electric Dryer
Miele Novotronic T240 Electric Dryer Logo
81 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
