Question about Coffee Makers & Espresso Machines
We have M200 Magimix Nespresso, it is leaking from the valve at the bottom of the water resevoir, it is brand new, do we take it back?
SOURCE: Nespresso Magimix M300
Try rescaling the machine.  The following is a PDF of the instructions:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
Posted on Apr 14, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Nespresso Essenza D100 leaking water while brewing
Sounds like a gasket or seal gone or a split pipe.
If it's still under warranty - take it back for free service or replacement.
If you do have to attempt DIY, then a clear silicone sealant may save you the price of expensive gaskets.
Be very careful when taking apart - take notes or photos as it will help put it back together !
I usually put related sub-assemblies together with their screws in separate pots.
Posted on Aug 11, 2009
SOURCE: Nespresso Essenza C100 leaks all the water out
I have a nespresso type D90 which does exactly the same thing so it is probably not just yours
Posted on Feb 09, 2010
SOURCE: My Nespresso machine is the
Have same problem with my Citiz
Posted on Oct 18, 2010
SOURCE: Need manual for Magimix Nespresso machine M300.
Check the magimix website...All the manuals are online...
Posted on Mar 04, 2011
The part that holds the water is cracked can I get a new one as its leaking
If it is Nespresso branded then contact them, check on Google. If it is another brand but using the Nespresso pods then contact the distributors of that other brand.
Jun 15, 2015 | Nespresso Coffee Makers & Espresso...
Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
May 15, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso machine repair
I have a citzi machine and it started leaking water from the bottom, not from resevoir...HELP
Jan 05, 2014 | Coffee Makers & Espresso Machines
How to open a Nespresso Coffee machine ?
Try on the bottom of the machine, the foots should be removed and then you will see the screws...
I'm not sure about this, but it's the usual way to hide them...
Apr 01, 2013 | DeLonghi Coffee Makers & Espresso Machines
Water leaking from reservoir
I had the same problem. All of a sudden my kitchen top counter got filled with water. The water was leaking from the Nespresso C190 water resevoir at the bottom. Exactly where the reservoir meets the coffee machine base. I had by chance an "O" rubber ring left from a faucet which I inserted at the base of the water rervoir right on the small **** which when it sits on the C190 base lets a valve open in order the water to flow through. The "O" ring was 2 to 3 mm in diameter and about 1 mm thick, You might experiment with different ones until you solve your problem.
Jul 02, 2011 | Nespresso C190 Espresso Machine
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
User manual for san remo coffee machine (Capri)
i have one. Can send it to you . I am from holland
Jul 19, 2010 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
421 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
