Question about Cosco High Back Booster 22-200 /22-207
The belts i took apart to wash the pad and i dont now how to put it back
  • loosegoose1 May 30, 2008
    hrfjn
  • Shortay May 31, 2008
    Can I get detailed instructions on how to put this car seat back together? I took it apart to clean it and can't figure the belts out.
How do i put the belts bsck on
Posted on May 22, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Did you have the user manual
Posted on May 16, 2008
3 Suggested Answers
djxtreme979
  • 151 Answers
SOURCE: i need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
Posted on Dec 29, 2008
  • 12 Answers
SOURCE: Need to reassemble belt system
http://www.coscojuvenile.com/usa/eng/Instructions?ProductNumber=22216LLP
Just need to enter manufacture date to get the manual.. The instructions should be in there to reassemble the belt system..
Posted on Sep 08, 2010
Drum stopped spinning. I took apart and took out the broken belt. Not positive if thats the only problem. I found a one inch in diameter plastic piece that seems to be broken, also. Not sure how to put it...
The plastic piece maybe the pulley on the end of the motor. Check the motor for a drive pulley it will have grooves in it for the belt. Since you are in there check the idler pulley for ware, the drum support pulleys in the back for ware, and see if you have any glide pads for the front of the drum. When you put it together put the belt around the drum before you put it in. Before you secure the front of the drum put the idler pulley on the belt. As long as you do not end up with extra screws you got it back together right.
Jun 01, 2011 | Dryers
Jul 11, 2010 | Cosco Juvenile Scenera Convertible Car...
My kenmore 70 series washing machine wont spin. i took it apart and could see the belt off, but i couldnt figure out how to put it back on
just place the belt over the motor pulley
then get it started over the drum pulley it will stretch on by rotating the drum pulley
Mar 09, 2010 | Washing Machines
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Belt slips on the agitator pulley
i got the same problem the belt slips on the spin cycle i have replaced the pulleys the belt and the tensioner worked well for a week then back to slipping took the whole machine apart and found dryed up grease in the top seal and on the shaft cleaned it all of put new grease on worked fine for two months today same thing again took it apart and the shaft is all gross and stickye with dryed up grease i just like to know what grease a guy should use
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
HNF7167 Hoover Washing machine no spinning
how do i put the belt on my washing machine
Dec 07, 2008 | Hoover AAA160 Front Load Washer
Taking apart for washing
disconnect the belts and snaps, it takes a little time to figure out how everything disconnects but it all comes off and you can wash it
Jan 23, 2008 | Eddie Bauer Lightweight Travel System...
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Cosco High Back Booster 22-200 /22-207 Logo
507 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
