Question about LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator
One of the fuses on the microprocessor panal the back of the frig is burned out
  • LG Master
  • 17,129 Answers
If on replaccement of the same rating of fuse blows out then the microprocessor board must be investigated for a short. It can be failure in the power supply or a protector or a regulator but will not be difficult to confirm as a multimeter in continuity range will be able to figure out the short in the tested line.
Use the logic to check from the fuse to the board, release off any connector to confirm the section.
Posted on Aug 28, 2010
If panel lights up and gages all say zero is it possibly a fuse?
I would suspect a poor connection on the back of speedometor panal. Remove panal and check your electrical connections .
Sep 02, 2014 | 2002 Ford Explorer
1999 ford explorer fuse panal diagram
I don't have a diagram, but you will just have to pull fuses out individually and check, or use a flashlight/torch and sine it from the back side of the fuses of they are the clear type. You can often view the filament then to see if it has burned out.
Nov 01, 2012 | Ford Cars & Trucks
My Panasonic sa-ak770 will not turn on there is no power going to the unit at all
1. Fuse inside burned. or
2. Broken power cable or plug.or
3. Microswitch demaged or
4. Microprocessor or...
Oct 14, 2012 | Audio Players & Recorders
My stereo/cigarette lighter/clock stopped working in my 2000 corolla. any suggestions?
Check the fuses. There should be a fuse panal inside the car on the drivers side. There will be a diagram on the inside of the panal door telling you which fuse is for what.
Sep 19, 2011 | Computers & Internet
My door locks and ligh burn where can i find it
as u open the door on driverside u will see a fuse panal cover. opwn it and u will find the fuse for the door lock and light.
Mar 30, 2010 | 2003 Dodge Neon
Model ler8857eqo wont start has powr timer makes clicking sound when timer is turned off start button clicks back out
you nead the unplug the dryer and pull the dryer away from the wall to get to the back panal.next remove the vent hosefrom the dryer.next remove the back panal and the power cord cover.if you look down and to the left you will see a white plastic thermal fuse.remove the wires from the fuse and check that it is closed.if it is open the replace the fuse and reassemble dryer.
Jan 19, 2010 | Whirlpool LER4634J Electric Dryer
GE Profile side by side freezing everything
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219577
thats what you need its not that hard to put together
thats the kit that allows air into the fridge and its allowing too much, before you order this  go to the back of the fridge and take off the silver panel  with about 10 screws take off the control board take off the wires and it has clips on each corner of the board get needle nose pliers and squeeze the white plastic that extends out of the clips and pull the board towards you got to do that for all 4 corners once you do that check on the back of the board for black smudges and burning smell if there is significant black smudge or burning smell you need to oder that but im 97% sure you need the inlet assembly
its located in the middle upper part of your fridge
Jun 08, 2009 | GE Profile PSS26NGS Side by Side...
Turn signals dont work at all the green arrow doesnt even come on i already replaced the flasher relay but im being told there is another one where is it
hello. check you fuse panal. look in the user manual that came with the car. it will have a fuse panal diagrame of what fuses control what. check if the twight senenal is working. it might be burned out. it will be located behind down to the right of your cruse control on off switch. wiper switch top headlight switch mid- cruse bottom. your cruse control switch and your headlight switch will have to be removed to get at the twilight sentenal switch. mabe your turn signal lights are buned out. you can replace them. you will have to remove your speedometer panal to get at them. an other posabllity is that your turnsignal switch on the steering collom isn't working. I segest that you buy the haynes repaire book. you can get it at canadiantire. and online at amazon.com. your fuse pannal should be down on the bottom left on the drivers side underneath the dashboard where your parking break is.
Dec 22, 2008 | 1989 Cadillac Brougham
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
