Question about Kodak Easyshare M753 Slim Digital Camera
I think i have connected the wrong charger/adaptor now cameraseems dead?????
  • Kodak Master
  • 17,129 Answers
Unless you are lucky the chances are very dim. But take a chance and get teh camera opened to find the right issue . A check on the board will indicate the fault. however if you lucky the prrotection zener would have shorted and saved the main board.
So check this out but take help to open and investigate.
Posted on Aug 28, 2010
My dell latop wont power on but the charger is working. What should i do?
How do you know it is working? Do you have a volt meter for dc, what reading do you get? It should be near the spec on the adapter. I have had several fail at the computer plug connection. A little wiggle may confirm. For emergency I taped it with a splint.
Any chance you can swap adaptor and or battery with a friend to verify? If your battery is charged, it should boot. My bet is the battery is dead because the adaptor is not working properly.
Mar 28, 2015 | Dell Computers & Internet
The ac power adaptor ac-v515 is dead.
I can't find the AC v515 adapter any where! But You can buy the next best thing. A battery charger one that will at least fit an NP-F730 battery. Go on to eBay and type Sony vc1000 and anything related will come up. These chargers can be used in your car and at home, what's more they are not expensive.
Nick
May 02, 2012 | Sony Handycam DCR-VX1000 Mini DV Digital...
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
I already replaced my charger once. This is the second time it just wont charge my laptop and it hasn't even been a year since I replaced the last one. What is wrong?
guess the problem is with your laptop battery....chargers normaly dont crack soon.....
charging the battery....is not OK
to sort out the issue
do this...
1 remove the battery from the battery bay....(hope u know how to do that)
2 now connect the adaptor and check if the notebook works....(without the battery in the bay)
3 now remove the adpator and install the battery...check if it now works with just the battery....
4 now connect the adpator to notrbook with the battery in it's bay...start the notebook.....and let it work for some 3 - 5 hrs
5 remove the adaptor...check if the battery immediatly takes over...if not then battery is the issue
Feb 17, 2011 | Compaq Presario CQ60215DX Laptop Charger...
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
MY COMPUTER WON"T TURN ON YET INDICATOR LIGHT WHERE CHARGER GOES INTO IT SHOWS LIGHT> Plugged in but will not powerup screen black. THIS IS A G60 HP Laptop
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 16, 2010 | HP G60-235DX Notebook
I CONNECT THE CHARGER AND THE CHARGER DON'T CHARGE THE LAPTOP. NOW I I REMOVE THE LAPTOPS BATTERY AND PLUG IN THE CHARGER AND THE SAME THING HAPPENS THERE'S NO LIGHTS, NO POWER AND THE BATTERY IS DEAD....
There are 2 possible problems with your notebook.
1) Adaptor/Charger problem. (common)
2) Notebook power problem. (slight)
To check if there is a problem with your charger.
a) Plug in charger to any wall socket.
b) Get a small solid wire (prefferably insulated).
c) insert one end of the wire to the positive point of the adapter or the inner side of adapter.
d) scratch the outer side of the adapter using the other end of the wire to check for sparks. a spark is highly visible on a 12v power.
e) if no spark is created, then there could have been a problem with your charger.
Hope this helps.
Mar 23, 2010 | ASUS Eee 4G Notebook
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
My dynex portable dvd player 7 inch screen wont turn on!
Tries buy a new litium battery yet?Get a new adaptor charger?Tries it own website for adaptor charger or Amazon.com,Ebay.com many eclectronics parts excessorries.Tries ur local Radio Shack ask the clerk for help to buy litium battery or charger adaptors.
Oct 04, 2009 | Dynex DX-PD510
Kodak Easyshare M753 Slim Digital Camera  Logo
20 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
