Question about Irons
How can I remove something that has stuck to the bottom of my iron
  • 377 Answers
Not a one step process. Depending on what it is, I would start by turning the iron on to HIGH to heat the material up. I would then wipe it with a cotton rag, a bunch of old newspapers, or if necessary, scrape it with a smooth piece of wood like a paint stirrer. You can get paint stirrers free at Lowes or the Home Depot. At some point it might be necessary to rub with a VERY fine steel wool to clean up any tough spots. You should only do this if the iron is not coated with something special like Teflon.
Posted on Aug 29, 2010
  • pwillitz Aug 29, 2010
    Very sorry my suggestion was not beneficial to you.
    The process has worked twice for me in the past.
Steam button stuck
put some vinegar in your iron and swash it around. It will remove the calcium or lime that is making your button stuck. Be sure to run a lot of water through the iron after or your clothes will stink.
Apr 24, 2013 | Black & Decker Irons
Have sticky substance on bottom or iron - howcan i get it off?
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Mar 01, 2013 | Singer Irons
Something burnt on the bottom of soleplate. Will not iron off.
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Nov 29, 2010 | Tefal Ultraglide 1549 Iron
I am unable to stop the steam at the iron. The trigger doesn't appear to be stuck.
I would first try with household vinegar (empty as much water as possible) and if that doesn't work to free the valve, then something more aggressive containing acid like any of the Lime Away type of lime/rust removers. If it is still stuck, you may have to bet the iron hot to make the acid more effective. If using other than vinegar, I wouldn't advise allowing anyone to breath the vapors; do this in a utility room or basement.
That trigger probably acts on a needle valve that controls the flow of water to the point at which it is turned to steam and it may simply be too contaminated with lime buildup to slip back into the valve body.
Jan 10, 2010 | DeLonghi Stiromeglio Compact PRO 300 Iron
Fleece shirt melted on the bottom of non-stick iron
well try heating the iron and rub the wax on the heated iron and wipe it off using cotton cloth
Jan 04, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
I got something on the bottom of my rowenta steam iron. How do I remove this? Can I use an SOS or brillo pad?
I would not use that type scrubbing pad. It will probably get steel fibers in the steam ports -- if you don't get them all out you could get rust on your clothes.
Try a stiff fiber scrubbing pad -- non-metallic. If you use soap, check to see if the steam ports need cleaning of whatever soap may have gotten in them.
And then maybe run some steam though the iron -- like steam iron an old rag to clean it up before actually putting the iron on good clothes.
May 09, 2009 | Rowenta Professional DX8900 Iron
Need to clean my Rowenta
let warm up and spray a good oven cleaner on it and let sit for awail(turn iron off) then it should just wipe off!
Please rate this answer!
Jan 23, 2009 | Rowenta DG-980 Iron
I have something stuck on the surfance of my iron. I need to know what to use to remove it. It is staining my clothes when I iron.
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do this if it is teflon coated. Hope this helps you.
George
Jul 15, 2008 | Conair Compact Garment Steamer Iron
Open Iron
on most common IRONS , theres a screw located on the back where the main cord is , underneath it , AJ
May 15, 2008 | Sunbeam Classic 3957 Iron
Irons Logo
57 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
