Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Whirlpool side by side
I have a model number ed2choxkoo5 whirlpool and do not have the instruction book. all i got was this very long plastic tubing. how do i hook it up to my water line??? i have a side by side with ice and water
fridgetech
  • 473 Answers
SOURCE: whirlpool pin retainer is broken on ice dispenser
You don't have to replace the whole door. There is a kit that comes with instuctions. You can get it at www3.sears.com and the part # is 2206423 and switches over to #8201649 and is called door mechanism assembly. It is $42.99. Use # 2206423 for lookup purposes. Hope this helps.
Posted on Oct 09, 2007
  • 8 Answers
SOURCE: whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Posted on Mar 22, 2008
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
tborn6
  • 700 Answers
SOURCE: whirlpool side by side fridge ice maker quit working
its soundss like iuts stuck in defrost mode.
Posted on Apr 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: mold in water dispenser tube
Your refrigerator has a filter system below the bottom and behind the kick plate. Two or three times you need to turn the water supply off to refrigerator and fill the old filter with clorox to kill the algae growing in the storage tank and after you finally get this out and purge the chlorine from system will you be able to use the ice or water to consume. I know this seams harsh but really there is very little else that can remove this without changing the whole water system. Once this is done change the filter regularly and this will help, click on link below and place your model number into the model search feature. This will give you pictures of the parts and there location. Let me know how this goes, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 24, 2009
Leaking ice maker
I cannot provide information on the particular problem but I suggest you find the model and serial number of your refrigerator and search the Whirlpool website for any service bulletins or recalls. In the meantime keep the water turned off to the refrig. until a repair is identified.
Aug 19, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Schott Ceran. I have no instruction book and I find it trial and error to turn it on.Is there a book on line , Richard
I would try to get the manual for you but I would need your Model Number for that so here is the next best thing. Go to this site, http://whirlpool.com/home.jsp then in links along the top you will see OWNERS CENTER if you hover above that tab you will see that Whirlpool has supplied us with all the information we could need. Just click on manuals and follow instructions.
Thumbs up if I helped you!!!
Feedback is greatly appreciated!!
Good Luck!
Jun 15, 2011 | Whirlpool Ovens
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Instruction book needed
Hi Tracy,
Try this link. You should just need the model number ...
http://laundry.manualsonline.com/manuals/mfg/whirlpool/whirlpool_compact_dryer_product_list.html?s=fpw
Copy this into the address bar of your browser.
Cheers Gazzam
Mar 22, 2009 | Whirlpool Dryers
Ice maker whirlpool fridge
FIRST MAKE SURE IT'S ON,,THEN YOU NEED TO SEE IF YOU HAVE WATER TO THE WATER DISPENSER,IF YES CHECK THE TUBE GOING TO THE ICEMAKER,PULL TUBE OUT LOOK INSIDE TO SEE IF FROZEN LOOK TO SEE IF THE WALL WHERE TUBE GOES IN IS FROZEN,IF NO TO BOTH YOU HAVE A BAD INLET WATER VALVE,TURN WATER SUPPLY OFF,REMOVE PLASTIC TUBING FOR ICE MAKER AND DOOR WATERGOING TO WATER INLET VALVE,GET THE PART NUMBER AND GO TO YOUR LOCAL APPLIANCE PARTS STORE AND GET THE NEW PART,REPLACE TURN ON WATER AND ALL SHOULD BE GOOD,HOPE THIS HELP,THE WATER VALVE IS ON THE LOWER BACK SIDE OF FRIG.
Jun 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool refridgerator ice maker
Check your water valve. Most likely it is leaking by the seal on the icemaker side of the valve so that it is getting a slight trickle of water all the time to the fill tube. This will freeze in the tube much like an icecicle is formed. This is the most common cause. Low water pressure and mineral deposits inside the tube can cause it also, but it usually will take longer than a few days for the problem to reappear.
The dispenser housing and parts on your fridge are replacable and show to still be available.
You can go to sears.com, click on parts, enter your model number, and see parts diagrams and lists for your fridge.
This link should go directly to the parts site.
http://www3.sears.com/
Post back and let me know about the water valve.
Thanks/Mike
Jan 06, 2008 | Refrigerators
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
