Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking green timer light
Hi my name is rick and model # is WD 62725 mitsubishi tv v26t chassis I unplug the tv and plug back in and this is the problem I have the green timer light keep on flashing I change the 4 cap on the power board and 4 cap on the board that has the usb cable I know if thatis the dm board thank you
Cannot turn on TV. Has constant rapid flashing green light. Have tried reset button and also turning power off to TV completely for short period of time. TV still does not turn on.
  • rustyo Jun 25, 2008
    62" DLP.
    same blinking timer light problem
  • Anonymous Mar 30, 2014
    Try to update my Mitsubishi WD-60638 DLP TV firmware. Followed the instructions. It stay at the welcome screen for an hour. Try to restart the firmware update by turning it off. Now its stuck at the welcome screen now. Wont get pass that. I've try to redue the firmware update over and over but nothing.
    Update: I just released that the usb port isnt getting any power. Normally when I plug my usb into a port, it lights up but with the tv's port, it doesnt light up. Plugged in my Ipod (because if its plugged into a usb port, the screen turns on)into the tv usb port but nothing. This tells me no powers getting to the port. I just want to know what part do I need to replace in order for it to work. The Formatter Board or the main board?
  • 3 Answers
I have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Posted on May 07, 2008
2 Suggested Answers
SOURCE: blinking green timer light
i got mine back on by doing this but if you unplug from wall you will have to do it again ok uplug the tv from wall then you have to unplug the power plug from the FMT BOARD then plug it back in the wall wait till the green light goes out up to 2 min then plug the FMT power back DON'T UNPLUG from wall then hit the power on the tv.
Posted on Apr 07, 2011
Replaced the bulb and tried to turn tv on and a have a green blinking light that came on nothing else. Please help
Thas a very common problem for that model which happens when the power cord is unplugged. Failed caps on the DM and the Power boards wont re-charge when power is restored and the timer light blinks non stop. The V26 Chassis DLP DM / Power repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with repair instructions.
Oct 21, 2010 | Mitsubishi WD-62725 62" Rear Projection...
The power went out at my house for about two seconds and when it came back on the TV timer light started blinking and has never stopped. I have pushed the reset button and have also un-plugged the TV and...
Thats a common problem when the power goes out the weak caps can no longer charge and then the led will blink green non stop. www.tvrepairworld.com has the Mitsubishi V26 Chassis DLP DM/Power repair kit should solve that problem. The kit contains the capacitors and the CD with detailed repair instructions.
Oct 07, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
Jul 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture after replacing lamp
the chassis needs to be rebuilt. go to www. tv-techs.com for more info
May 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much.  My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed.  I sure think Mitsubishi should be held more responsible than they seem to be.  Some one suggested a class action lawsuit.  I would sure join one.  Jack P
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
351 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
