Question about GE Deluxe AGM12AB Air Conditioner
I have a GE air conditioner, model #ASM18DBS1. It seems that some of the touch pads on the control panel aren't working. The On/off works but the temperature up and down and the energy saver aren't working. The remote control isn't working either.
dvs_redstorm
  • 81 Answers
SOURCE: I need to replace the
you can get a universal tv remote that also does air conditioners or a remote that does all air cons but there costly.
Posted on Nov 09, 2010
justaplumber
  • 98 Answers
SOURCE: touch pad on
It is more than likely the touch pad that is faulty. I have installed many bonaires, and the only thing to go wrong at that age is the touch pad, or the problem is in the control box in the airconditioner.
The touch pad comes off quite easily by placing something flat behind the pannel and leavering it off gently. The touchpad has two pieces, the front, which you see, and the mounting bracket. The bracket is almost as big as the front pannel, so you only have approx 2-3mm of plastic edge to lever, so be careful not to hook onto the mounting bracket as well.
Once you have removed the front, you can then unplug the lead coming from the touch pad (be sure to turn the control box off in the airconditioner before removing this wire, there is a switch on the side of the control box (yes, you have to get on the roof, sorry)). Take the touch pad to your local retailer that sells Bonaire units and see if that is the problem.
Posted on Jan 11, 2008
TheMobilian
  • 8220 Answers
SOURCE: model A6T12F2A. digital control panel is stuck on
More than likely you is gonna have to replace the control.Sometimes getting a wash rag real hot and going over the buttons will help unstick them.
Posted on Jun 25, 2009
daddyo742001
  • 70 Answers
SOURCE: This goldstar air conditioner model is WG2405RY7
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Posted on Jun 30, 2009
relaga58
  • 158 Answers
SOURCE: air conditioner not working
have you tried turning off and on power from the plug ?
Posted on Aug 17, 2009
My GE Cafe microwave touch pad will not work. Everything seems to be working. It is a built in , above the stove 2008 model.
Here is the information page on the repair of GE Cafe microwave ovens.
http://www.microwavecontrol.com/jvm2070.htm
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | GE Microwave Ovens
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
Touch pad won't change settings, stuck on rinse cycle
It seems like, it is touch pad control panel problem and depend on brands, without knowing brand name and model number price of touch control could be between $100 less to $200 or more plus labour to replace
Sep 08, 2013 | GE 24 in. Profile PDW9880JSS Built-in...
New ge 18000 btu air conditioner touch panel not working
Normally you shouldn't operate an a/c without remote. You have to replace touchpad.
Sep 06, 2012 | GE Heating & Cooling
I have a GE window air conditioner about year old. It comes with the digital control panel. The light on the power supply cable is on and it passes the test (it trips as it should) however the unit does...
Some of them controls has a small fuse mounted between the touch pad and the control board. If yours is not lit up then the fuse is all ya need. Take the old fuse to radio shack. Unplug the unit if you decide to look. If the control is bad and costly yall can bypass the controls.
Jul 09, 2011 | GE Heating & Cooling
I believe error E9 is a touch pad error. Shouldn't the unit still work via the remote?
No the control panel recognizes the error pre remote signal therefore the remote won't work either. You may need to replace the touch pad.
Aug 12, 2010 | Friedrich QuietMaster Electronic SS12J30D...
GE Deluxe AGM12AB Air Conditioner Logo
78 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
