Question about Apple iPhone Smartphone
Iphone got wet in rucksack (not dropped in water) and now screen remains very dim even if I ajust brightness and do an on/off and 'reset settings'. Any idea how to fix this one? Paul
  • cowans Aug 28, 2010
    Thanks, I've already done the hairdryer already. Before that there was nothing at all. Post-hairdryer, it works but v dim screen. Paul
  • 881 Answers
To eliminate moisture from the inside, the only thing you need to do is get a bag rice (just a small bag enough to bury in and cover the whole iPhone). And leave it tightly sealed for a day or two. A ziploc bag is a great choice, but make sure, you fill it with rice. The bag should contain as much less air as possible, and the seal should be airtight.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Posted on Aug 28, 2010
  • Apple Expert
  • 2,973 Answers
Use a hair dryer and blow into the phone. DO NOT put the heat on else the phone may get toasted. It will remove all traces of water from the phone.
When I go to text portion using kindle books, the page dims even if the brightness setting is at max
The option to keep the display bright is not found under settings in the Android app, but under the font settings. If you tap the centre of your screen whilst reading your book the icons will appear at the top of your screen. Click the font size icon, and a drop down list of settings will appear. The one at the bottom deals with brightness.
Mar 14, 2016 | Samsung Galaxy Tab 2 7.0
Iphone 4s sometimes when I turn it on it's dim?
You have to go to Settings>Brightness and Wallpaper and then set Auto-Brightness to OFF.Then select the appropriate brightness that you want from the brightness slider bar.
Mar 19, 2013 | Apple iPhone4 4G iPhone 4
My iphone got wet now light is so dim i restored it and everything but it is still dim i can do call and receive calls everything else works great execpt for the light what can i do.
First, check your brightness setting. Usually I'd give some other troubleshooting tips, however the fact that the phone got wet tells me that the screen itself has water damage. A good trick (something I've done many times) is crack the screen then take it to the Apple store and ask for a replacement. They have a "One-time exception" and will replace the phone for free. Hope this suggestion helps :)
Aug 18, 2011 | Apple iPhone Smartphone
I dropped my phone in water the other day while the phone was powered on. I tried turning the phone off and then back on. The screen flickered several times and then went dim. I powered the phone...
It is something that can be saved. You will need to replace the screen and digitilzer or reset all settings. You can google scrren and digitilizer and you can purchase it online and install it yourself. Or you can take it to a phone repair store and get it repaired for about 40-100 dollars. hope this helps.
Jul 28, 2011 | Apple iPhone 3GS Black (16 GB)
Iphone 3.2...my iphone light is too dim automatically i dnt knw wht happen...screen is ok but light is too dim to see...
There are only ? handful of possible causes for the problem which you are facing. The most common being the light settings for your device. The brightness of the light might have been tampered with. Simply go to settings and adjust the contrast and brightness of the phone.to your taste. If this happens not to be the case then the bulbs for your screen are bad and therefore have to be replaced. This will have to be done by an expert. Hope this solution has been helpful?
Jun 20, 2011 | Apple iPhone Smartphone
My ipod touch works perfectly however i i turned it of once and the screen went blank almost completely. i could hardly even see it under a realy bright light. how can i fix this? or is it unfixable, do i...
Greetings,
After many years of developing for the iphone, I've come across this problem many times.
  1. If your ipod is stuck on this really dim lighting and connect be used, just leave it alone till it runs out of battery on its own.
  2. When the ipod is completely dead, just recharge fully.
  3. After the ipod is charged, proceed to turning it on.
  4. If the light is still dim, go to settings and set the brightness.
OR
  1. If your ipod is usable but you cannot change the brightness, reset the entire ipod manually (hold the on-off button for a few seconds).
  2. When ipod is shutdown, hold the on-off switch again and wait till it reboots.
  3. Then go to settings and change the brightness to your liking.
If you require further assistance, please feel free to reply to this post. Also please don't forget to rate me if I have helped.
Thank you for using FixYa.
Feb 17, 2011 | Video Game Consoles & Games
Iphone screen is dim
You will need to wait for it to dry out. Just one little drop of water getting into the wrong place can cause this. Put the phone in a sunny spot for a couple of hours and see if that helps. If not, hopefully your phone is still under warranty and you can take it to an Apple store for repair or replacement.
Aug 28, 2009 | Apple iPhone 3G
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
My screen has dimmed but the cursor remains normal
I think its just like driver problem or you adjust the color in under advance button in the screen and resolution setting
takecare
Apr 28, 2008 | Computers & Internet
Apple iPhone Smartphone Logo
349 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
