Question about Brother MFC 8820D All-In-One Laser Printer
ERROR 7A I HAVE A BROTHER MFC 8820D WHEN MACHINE IS SWITCHED ON DISPLAYS ERROR 7A ARE YOU ABLE TO HELP?
  • glesner Aug 22, 2008
    today 8-21-08 we had a power outage and have the same message ERROR 7A also at the bottom of my display it says to unplug machine and call Brother.
  • 1,218 Answers
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Brother MFC-8820D ERROR 6C ON UNIT DISPLAY CALL BROTHER
Did you try disconnecting the printer from the power to reset?
Apr 13, 2008 | Office Equipment & Supplies
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
Machine error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock. for more information and help........
Mar 04, 2010 | Brother MFC-8440 All-In-One Laser Printer
When i turn on my brother mfc 8440 it is saying
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Jun 18, 2009 | Brother MFC-8820D Laser Flatbel...
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8820D Machine Error A
Oct 02, 2006 | Brother MFC-8820D Laser Flatbel...
Brother MFC 8820D All-In-One Laser Printer Logo
599 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
