Question about SanDisk Sansa Clip MP3 Player
I formated sansa player nw it not detecting in my system when i conected guide me to solve the problem
  • 4,323 Answers
Hi
Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If not then reset the player while it is connected with the system. This will resolve your issue.
Hope this helps...
Daniel
Posted on Aug 28, 2010
I re-formatted my Sansa e280 and now my computer does not recognize it. I am wanting to transfer music files only, using Windows Media Player.
Try to reset the device and if there is any driver for it, install them before connecting it to the computer.
Feb 28, 2011 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
I formatted my Sony mp3 NW-S603, How do i fix it?
Install Sonic Stage software supplied with NW-S603 in your PC, plug MP3 player and software will install system files in mp3 player along with music files.
This will solve your problem.
Feb 01, 2010 | Audio Players & Recorders
How to install Sony NW-E005
Sony support for the NW-005 is on next site;
http://esupport.sony.com/LA/perl/model-home.pl?Change_Template=1&session_id=7939e283f3ebb5ca28bdc3fc98c42e32&mdl=NWE005&LOC=3
You can use the quick start guide for installing the player.
Quick Start Guide;
http://www.docs.sony.com/release/NW-E00xF_QSG.pdf
More information about the NW-E005 look in the operation guide.
Operation Guide;
http://www.docs.sony.com/release/NWE002F.pdf
For both guides in pdf format Adobe Acrobat Reader has to be installed,
before the files can be read.
Need more assistance ? Just post a comment.
Jan 01, 2010 | Sony Network Walkman NW-E005 MP3 Player
My SONY NW-E002F mp3 walkman, 512 mb tells me
1.reset device.remove battery.and try again.2.clean MMC of dirty. good luck
Dec 05, 2009 | Sony Audio Players & Recorders
Sansa e260 not recognise,cannot format it
Ok first try to calm down, take a look at the back of the player and you will see 4 very small phillips screws, remove these and take the battery out of the player for about a minute then put it back in and see if all is ok, this will most times solve all problems but you may lose some if not all of the content in the player.
Feb 23, 2009 | SanDisk Sansa e260 MP3 Player
(e260R) Refresh Database eternal loop
Turn it on into recovery mode (Hold + Record Button + Power)
Connect to computer (You should detect a 16MB drive)
Make an empty text file inside the 16MB Drive and rename it to "sansa.fmt"
Unplug the Sansa. You should see now a "Formatting..." on the Sansa's screen.
Sansa fixed!
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Sansa c150 MP3 player hung
try to format the player and see whether the system detects it ??
else try to detect through scan hardware changes...
Jun 21, 2008 | SanDisk Sansa c150 MP3 Player
Please help my sansa e260
ok plug it in to computer look for driver g click on it then format this will solve your delema
Jan 18, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
