Question about Motorola Mobility RAZR V3xx Cellular Phone
Replace lower housing
After removing old key-pad, keyboard, internals, etc. how do you dismantel the hinge (the flip housing) from the front housing. I have removed the two screws and little plugs on each end. It's loose on one end, but not the other.  I am tryng to replace the front housing.
    Sergeant:
  • 154 Answers
My best advice is for dismanteling the elements of phone give the set to local service station because if by chance we dismantelled important elements the warranty will be void.. so better avoid this... hope i have helped you.
Posted on May 07, 2008
  • santha ram
    santha ram May 07, 2008
    thank you sir
The buttons on my phone do not work ;(
For many cell phones, the buttons are the main way -- and sometimes the only way-- that you can interface with the device. Most cell phone buttons are simply small domed pieces of metal that flatten out when you press them, completing a circuit with a metal pad on the circuit board and allowing the software to register a keypress. If you need to fix buttons that have stopped working, you'll first want to try some simple fixes, but you will probably have to open up the device.
1.Remove the device's battery, wait about 20 seconds, then replace it. Software errors sometimes interfere with the keypad operation. Removing the battery will reset the software and if the buttons start working again, you will have saved yourself a lot of effort.
2.Take note of which buttons are not working. Once you have the device apart and are staring at the internal keyboard, it may be difficult to remember exactly which buttons are non-functional.
3.Remove the cell phone's plastic housing so that you can get to the keyboard. The exact method for doing this will vary widely based on your exact model of cell phone, but most will have small Phillips or Torx screws on the back side. Once you've removed the screws, use a pry tool to separate the housing and get to the keyboard.
4.Check the rubber keypad for damage. This is the part that contains the keys you actually press, the underside of which will have a small cylinder under each key. When you press down on the button, the cylinder pushes down on the actual keyboard. Any damage to the keys on the topside, or to the cylinders underneath, can cause an individual key to stop working. If there is damage, there is no way to fix it -- you will have to replace the rubber keypad.
5.Check the connector that runs from the keyboard to the rest of the circuit board to ensure that it is seated correctly and is not damaged. If it is damaged, you will have to replace the entire keyboard to restore functionality. Not every keyboard will have a cable, as some are installed directly on the control board, so don't worry if you can't find one.
6.Hold the heat gun about six inches above the keyboard. Turn on the heat gun and move it around the keyboard for about a minute. Do not hold the heat gun in any one place for more than a second or two.
7.Pry up the white sticker that sits on top of the keyboard. This sticker holds the metal domes, which are what get pressed down to actually cause a button press, in place. If the sticker is not coming up, apply heat for another 10 seconds and try again. Be careful that you do not separate the metal domes from the underside of this sticker.
8.Apply isopropyl alcohol to your brush and scrub the metal pads on the keyboard, along with any nearby components on the circuit board. Dirt, debris and moisture damage can build up on the keyboard over time and eventually cause it to stop working. Cleaning it is not a guaranteed fix, but it often helps.
9.Locate the metal domes, which are attached to the underside of the white sticker, for any individual keys that are not working. Place the tip of your small screwdriver in the middle of the concave side of the dome and pull the edge toward the screwdriver. Sometimes, the domes will lose their ability to fully depress, and this process will restore this ability. Don't pull too much -- just enough to add a slightly greater curvature to the dome. Note that this process should be used only when a single button is non-functional. If a group of buttons, or all the buttons, are non-functional, the problem is elsewhere.
10.Replace the white sticker, ensuring that the metal domes are positioned exactly over the metal pads on the circuit board. Reassemble the device and try out the keyboard. If the keys are still not working, the keyboard is probably never going to function again.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Motorola Mobility L6 Cellular Phone
My hinge like just poped out when i flipped it open once... its still works and it can sense when i flip it sideways or vertical... but like its hanging on by a little strand of like wire and i cant flip...
usually the mechanism is supported by spring loading. so you wont get a good result after superglue. very likely it will pop out again.
solution is to buy a new housing - i.e. phone without its circuits. and transplant your old phone to it.
Jun 30, 2011 | Cell Phones
Motorla razr v3xx
well pop the back off ,remove the battery.then there are 2 screws that hold the modem in place.remove them and very carefully pry the modem off.there are 2 plastic tabs near the bottom of the phone 1 on each side.careful or they will break.`then there are 4 screws on each side of the screen,when opened..they are under little rubber pucks.remove them and separate the 2 half's..Unplug the flex cable from the screen and carefully remove the screen and camera assembly.be carefully not to tear off the flex cables that hold the 3 buttons on the screen in..then if you'll turn the phone back over.where the battery goes in on the hinge .you'll see another screw.remove that and flip the phone over again.carefully pop the chrome hinge pin out.then you'll be able to separate the 2 half's.then there are 6 little metal tabs that hold the keyboard in place.pry them up and carefully remove the keyboard and flex cable.careful around the hinge,where the flex cable runs threw.
now moving on to the modem, on the bottom you'll see 2 little plastic tabs carefully open them and remove the brass retaining wire and the modem will then come out..get your new covers and reverse this process and you'll be good to go.
May 11, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
Pantech MATRIX C740 slide hinge has come loose. How do you take the phone apart to fix? (Pantech Matrix and Duo are not the same phone)
i suggest not taking the phone apart. 5 of my friends and myself have the matrix and after flipping it a couple of times the hinges are always going to feel loose. they have felt that way on mine for over a year. and if you take it apart, the senor bars for the keyboard will go out and you will have to get a new phone or just use the number pad
Jan 10, 2010 | Pantech Matrix Cell Phone
How to dismantle the housing of my P910i without damaging it?
On your flip top key pad, you can remove first the middle cover, it is clip type so no need to un scew, but just be very carefull.
after removing it, you'll see to set of screw, remove it so that you can take out the flip key pad,
turn your unit back, near the camera , there are two small cover there , remove it and you will see two screw, take it out
open the battery cover, remove the battery and sim card and the memory card, inside you will see, again two set of screw, take it out,
now all the screw has been removed
on the side oy your unit where you ca find the scroll, try to plip out the cover usig a twizzer or any pointd object, just flip the cover easily until you where able to remove the topcover completely
now just support the LCD, be very carefull so that may never damaged the flex of your screen
at the back of the screen, there are again another set of screw, remove it slowly, make sure that you supported the screen properly
then you can remove the lcd after taking out the stainless cover protection
removing the board is very simple, just lift the board a little higher enough for you to see the back of the board, there is another flex wire attached to the board and the scroll switch, remove it carefully.
then thats it, you had dismantle your unit
Nov 01, 2009 | Sony Ericsson P910i Cellular Phone
Replace flip on my nextel i850 phone.
1. Remove battery cover and battery
2. Remove the four T-6 screws from back of the phone (you will have to raise the antenna to access one of them)
3. Seperate the housings.
4. Disconnect the flex connector/data cable that connects the back housing to the motherboard.
5. Disconnect the cable attaching the flip to the motherboard (at top of board)
6. Remove keypad from old part and put it in the new part.
7. Insert motherboard into new flip/front housing and connect cable to board.
8. Reconnect cable from back housing to motherboard
9. Replace and tighten 4 screws and you are good to go.. very easy repair.
Mar 24, 2009 | Nextel i850
Top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
How do you change the faceplate on the nextel i95?
BASIC disassembly of your phone(i60/i90/i95)
This ONLY covers unscrewing the housing and splitting it open? that ALL. You'll need a T-8 torx driver for this.
Step 1: Turn you phone off, turn it over, take off your battery cover, take out your battery, and take out your SIM card. Be careful with your SIM card. Unscrew your antenna, remove it, and take out the metal antenna tube.
Step 2: Get your T-8 torx. Unscrew the THREE torx screws in the battery compartment. They are located in the bottom two corners and in the top left corner of the battery compartment.
Step 3: Peel back the right hand side of your ?Nextel? sticker just above the battery compartment. Peel it back ONLY A LITLE, until you expose the fourth torx screw. Use your T-8 torx to unscrew it.
Step 4: Carefully separate the two halves of the housing. BE CAREFUL, and keep in mind that at the top of the phone (near the flip hinge) there are cables still attached (the flip ribbon cable and the headphone jack). You will not be able to separate the two halves of the phone body all the way and will want to make sure to keep the top part of the housing relatively close together. If you screw up and damage the cables up there? don't try to blame us? we warned you.
Step 5: Do whatever it is you wanted to do that required you to split apart the housing in the first place (e.g. replace a keypad, PTT buttons, etc.), put the two halves of you phones body back together (carefully aligned) and screw the torx screws back in.
Step 6: Put your antenna, SIM, and battery back in, and you're done. Enjoy!
**Now let's talk about the flip. This ONLY covers the removal of the front and inside lenses of the flip. If you want to remove your flip completely, or remove the LCD of the i90. SEARCH the forum for info on how to do that. You'll need a T-6 torx, a SMALL flat-head screw driver, a hobby knife, and a blow-dryer for this.
Step 1: _This is optional, but is ideal for those nervous people out there who don?t want to take any chances. Remove your antenna and battery but put your battery cover back on.
Step 2: FIRST, open the flip. With the phone facing you (as if looking at your screen), look into the gap between the flip hinge and the phone body in the very center of the flip's hinge. You're going to see a small slot in there. Remember that slot? it's important.
Step 3: Close the flip and turn on your blow-dryer. Keeping the dryer about 4 inches from the surface of the front lens (the blue thing on the i95 or the silver thing on the i90) heat up the lens surface. Keep your blow-dryer moving around? DON'T concentrate it in one spot, you'll end up melting something. All you want to do is soften the glue a little. You don't need to use the dryer for too long to accomplish this. A minute or LESS should be fine, use your GOOD judgment.
Step 4: Once you have heated up the front lens enough to soften the glue underneath, quickly open the flip and use your small screw driver and poke it through that slot we talked about in step 2. You are pushing on the back-side of the front lens when you do this. BE GENTLE! You should be pushing the top of the front lens away from the top of the flip. Manipulate the phone in your hands as necessary so that you can hold the top of the front lens away from the phone. Remove your screw driver and close your flip (careful not to let the part you pushed away slip from your grip.)
Step 5: GENTLY pull the front lens away from the flip a little bit and use your hobby knife to cut away at the glue. BE CAREFUL not to knick or cut ANYTHING EXCEPT for the glue when you do this. In this process you will cut a little, and pull a little further away, cut a little, and pull a little further away. Continue this until you have completely removed the front lens. Once completely separated, make sure little to no contact is made with the glue on the back of the lens or the front of the flip. The more you touch it, and/or the more **** that falls onto it (dust or dirt or whatever) the less sticky it will be.
Step 6: Use your T-6 torx driver to unscrew the four torx screws on the front of the flip. These screw hold the inside flip lens down, so once they are out, be careful when you open your flip.
Step 7: Open your flip and gently remove the inside lens. BE CAREFUL. On the i95, the LCD is NOT glued to the inside of the flip. It is held in by the inside flip lens. You'll need to GENTLY remove it from the lens. If you're not careful.. you'll damage your ribbon cable and be screwed.
Step 8: Once your done doing whatever it is you wanted to do that required you to take your lenses off in the first place, just reverse the processes in step 7 and step 6 to attach your inside flip lens again. Then simply pres your front flip lens firmly back in place. If you were careful, the glue should be undamaged and would be PLENTY strong enough to hold your lens securely in place. Presto, you're all set! Enjoy!
May 29, 2008 | Nextel Cell Phones
Display
hi, Check if the external display working fine, also try to unfold slowly and see if anything comes to the display,coz this is normally the problem with display change over switch. all the best sreejith
Jul 14, 2007 | Motorola Mobility RAZR V3
Cant turn my phone on
sounds like you need a new flip
Sep 29, 2006 | Nextel i850
Motorola Mobility RAZR V3xx Cellular Phone Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
