Washing machine hotpoint wf541g nothing working start button flashing power to door ok but door lock indicater says door not locked had problem with water not filling to correct level so filled through powder tray to get it going worked ok now this problem any ideas please
    Problem Solver:
  • 6 Answers
Check door read switch ohms with multimeter if no continuity when door is closed replace swithch
Posted on Aug 28, 2010
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
Mar 04, 2015 | Bosch Washing Machines
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wd62 washer dryer does not start indicater light doesnot light up. have checked line fuse and socket thanks
It is probably a faulty door lock, a common problem.
Remove front of door seal by releasing the wire clamp, and unscrew door lock, it has 3 wires going to it, to prove it is the door lock, short out the 2 wires marked C and L ,it should now work, if it does not , then the fault is elsewhere,, but I feel confident this is the problem.
Please rate my solution.
Feb 28, 2010 | Hotpoint Aquarius WF000 Front Load Washer
All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Oct 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
'door locked button flashing'
The door lock flashing all time has nothing to do with the weather, or pipes freezing up, it is a fault with the washer.
It is unlikely to be a faulty door lock, but could be a broken door catch spring or door catch problem, make sure you can feel the door latch in securely.
the other probable cause a fault on the main pcb where you programme the washer.
Another prob that can occur is a fault on the mptor caused by the brushes shorting on the motor armature, this in turn can blow a track of the pcb, and giving you the flashing light prob.
I would start by checking the motor first, if you are satisfied that the door is closing o/k.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquaruis extra WMA A34 WASHING MACHINE
hellooooooo
Well its either the door interlock or the pcb behind the control panel....
What sometimes happens is that the door lock will blow the the pcb obard if there is an electrical short and if so you will need to replace both..
however sometimes its just the door interlock..
if you need advice on how to get to it then let us know cheers
Jan 11, 2008 | Washing Machines
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
