Question about Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop
My sr1120nx wont power up its like there is no power in the house i switched power cords nothing
  • joecoolvette
    joecoolvette Aug 29, 2010
    TaiFood, copy the URL of the link. Go to the bottom of the Solution box, and left-click on the Links icon. (Yellow Star) When the Insert Link box comes up, left-click in the box, backspace out http://
    Now paste the link into the Insert Link box, and click on Insert at the bottom.
    Scholar:
  • 104 Answers
Depending on where and how it is used the power supply is a major point of failure. Usually due to dust buildup or other air flow issues the power supply will overheat or cause a shutdown due to a fail over condition like no fan or cooling for the CPU. I don't believe the sr1120nx has a power switch on the back of the power supply but double check the obvious....twice. Also, make sure the 110/220V slide is on one side, 110V in the US. You should at least be able to see a fan or CDROM light flicker if the power supply is still able to gasp. Try blowing out the dust and use the opportunity to open the PC and clean it. Amazingly, my experience is that dust causes as many or more failures than viruses. here is the link for the service manual:
http://h10032.www1.hp.com/ctg/Manual/c00067151.pdf
and the parts replacement manual
http://h10032.www1.hp.com/ctg/Manual/c00225000.pdf
Posted on Aug 28, 2010
  • 4,281 Answers
Hi First make sure your main power supply is working fine,. Open cpu cabinet cover then pull cmos cell from motherboard for 10 minutes .Reconnect ATX power connector from smps power supply to motherboard. Then check. If still same then make sure smps power supply box is fine it is on the top of the cpu it is square box where power cable connected from main outlet. Change it then it will work again.Also make sure motherboard is not ground with cabinet cover. Let me know if you need further assistance. Thanks for using FixYa.
Electrolux Epic 6500 SR - power/cord light not lit, doesn't start & blows house circuit breaker
If your vacuum has had 20 years of service it may be simply too old to repair.
Apr 15, 2017 | Electrolux Vacuums
The machine won't turn on (no power light even). Trying to find the reset button. Where the cord enters the machine on the back ( top left) there is a a plastic cover housing the cord. I cannot see
Sounds like you have a bad door switch. Check to make sure there isn't a broken switch in the door housing. If not, this unit has a belt switch on it. Try spinning the drum by hand. If it's really loose and not tight, you need a new belt or the machine wont start.
Nov 25, 2013 | Dryers
Kmx02 wont turn on
Make sure the plug for the power cord is the same polarity and DC or AC for the mixer. Also make sure the inner diameter is correct for the station power jack as well.
As long as power from the supply is correct and adequate, theother potential sources of problems can be a blown internal fuse, broken power jack circuit tracks/traces, bad solder joints, dirty switch contacts, some contact cleaner sprayed in the gap of the switch toggle and then flipped rapidly for a number of times might clean it up.
Feb 04, 2012 | Numark Industries Numark KMX02 Dual Deck...
The pull cord on gas pressure washer wont allow me to pull it as though it is tangled up, But when i removed the housing, it woorks just fine
Sometimes the housing gets bent slightly. A lot of the housings have little taps or prongs that get slightly bent. I would take the housing off make sure it not bent or warp, to make sure there is nothing to block the free flow of then cord flowing. If it pulls fine with housing off, and hangs up when installed it slightly bent. Use small needle nose pliers and gently bend tabs away from area where cord is hanging up.
May 29, 2011 | Briggs & Stratton Prosumer 20324 Gas...
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
I have power to my orteck xl bagged unit but it wont
check the cord that goes from the handle to the brushroll housing. these usually go bad by the strain relief. also open up the handle and check to make sure the power cord wire didnt come disconnected from nthe switch, also a common problem. let me know if you need any further assistance
Jan 05, 2010 | Oreck XL Ultra Bagged Upright Vacuum
12 inch compound miter saw wont turn on anymore, was working earlier.
Could be the trigger switch or the power cord connection. For the switch pop the housing and disconnect the switch and hot wire the wires that went to the switch for a second and the motor will kick on or not. If not then the switch is not the problem. With the cord make sure your outlet is working then wiggle the cord.IF the saw was working before, these two things are the problem. If the saw was sparking alot while using it then it's the brushes and if run to long like this the motor is shot!
Nov 30, 2009 | Ryobi Saws
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
