Question about Umax Televison & Video
I bougt tv tuner card UTV330 10 months ago.It is not working may be short circuit. What to do next?
  • Umax Master
  • 17,129 Answers
Most often there is not much that can be done on the tuner card except if there is the failure of the tuner which can be changed with a chance.If short circuit it is easier to find as checking with a meter to see if it is a regulating device that can be changed easily.
If not since you need the use of one , you will have to buy a new one.
Posted on Aug 28, 2010
I have ASUS with Philips SAA7134 chip ,TV Tuner/FM Radio/Video PCI Capture Card ! I need a driver for Windows 7 (x86 and x64) ,and compatibile TV tuner software ! Thanks a lot !!
Hi! Sorry, give it up, there is no one correct driver for you card. I have the same and made a research around 4 months and no one driver worked correct. I made modification to the drivers and try a lot of programming but no one driver never worked. Forget it and buy another card but watch on the CPU!!! Do not buy a card with SAA71xx CPU! they will not work on windows 7 or vista.
Dec 23, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Necesito el driver de tv tuner philips 7130 w
Audio does not work on tuner. VisionTek TV Wonder HD 650. I tried reinstalling internally and externally,update drivers,and still no audio on my PC? I try other speakers and even earplugs all do not work....
m ake sure the jacks at the back is set correctly, from the tuner car auido out to the line in on the motherboard sound then make sur the aux cable is inside the case also fro the card to the motherboard mail me if any other questions, bertus_kriel@yahoo.com
Oct 08, 2009 | VisionTek TV Wonder 650 PCI Express Tuner...
Frontech tv tuner card jil 0606could not initialize capture devic
CLICK HERE
or go to http://www.sendspace.com/file/jxlowm
Download the file.
Driver, Software, Instructions included.
Oct 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
No video on my Zenith E44W46LCD 44 in. Rear Projection TV
your tuner circuit has failed not to worry though just look fot the fuses as the one that controls the tuner has failed replace it
Apr 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Mar 22, 2009 | Cyberhome DVR 1600 DVD Recorder
My Onkyo TX-SR500 receiver stays in standy/on mode.
It may be your amplifier protection circuitry is being activated and shutting down automatically. This is usually caused by a faulty output transistor in one or more of the channels. I recently repaired my Onkyo TX-SR500 which had this problem.
Using a multimeter on ohms check between C and E on each of the ten output transistors. I found Q6051 and Q6061 to be short cct on all pins. Once you have located the faulty channels check the adjacent components for open or short cct.
I replaced the following components,
Q6051 (2SD1047)
Q6061 (2SB817)
R6091 (2.2ohm fusible)
R6081 (2.2ohm fusible)
R6101 2x 0.22ohm 2W
Q6031 (2SD2061)
The amplifier now works perfectly, cost of the parts is about $15-$20.
If you don't feel confident doing this yourself just find a friend or tech who can do it for you.
Jan 11, 2009 | Onkyo TX-SR500 Receiver
Samsund recorder R130 will not play discs
Yea this is becoz all the normal discs are pirated or copied discs! Some of the original DVD players play only Original Silver Coated discs! They cant play any other normal DVD/CD
Dec 08, 2007 | Televison & Video
Morteza
Hi, unfortunately VISTA does not support a lot of devices that need drivers, XP had a fabulous driver base but Microsoft did not get the same up and running in VISTA, So go to the card manufactures web site and download the latest driver that is VISTA compatable. A lot of the software for XP will not run in VISTA. Regards mistyman
Sep 04, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Televison & Video Logo
99 people viewed this question
Top Umax Televison & Video Experts
Electro Med Services...
Are you an Umax Televison and Video Expert? Answer questions, earn points and help others
