Question about Ovens
Hi Blanco oven BODE 26/1 i need electric diagram to connect the timer Thanks.
  • Jerry Sep 15, 2010
    Just to clarify, the model is a Blanco BODE26X double wall oven. I have a new timer for the oven but the wires from the oven are not marked so I don't know which wire goes onto which spade connector on the new timer. Can anyone point me to a wiring diagram or provide me with the correct connections. Many thanks.
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: how do I remove the hinges from a Blanco BOS402
slide the oven out from the wall. You should be able to remove the hinge from the side.
Posted on Sep 13, 2009
Testimonial: "Not quite right but thanks anyway, I have removed the door as per instructions and worked out how to disassemble the door by removing all the screws"
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
Hi, my Blanco freestanding electric oven-FD9045WX-(gas cooktop) went out with a flash & a bang. The fan element was in pieces and the thermostat totally fried. The clock/timer does not go nor do the sparks...
Check for power at the supply terminals, follow it up to the high temp cutout > timer > multifunction switch > thermostat > element
Careful, don't electrocute yourself!
Oct 13, 2013 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
Oven Problem
http://www.blanco-australia.com/IgnitionSuite/uploads/docs/BSO632.pdf
This link should take you to the manual- if not, go to www.blanco-australia.com, link on "customer service", select "user manuals", and scroll thru to your model BSO632
Jan 15, 2010 | Bosch Ovens
278.4088891 Kenmore wall oven. The display goes black
Hi
Sounds like the "display" part of the timer is faulty or has a bad connection. As the cooker still heats up then the "relay" is working ok.
A replacement timer will be roughly £70 - £80
Hope this helps
Aardvark Repairs
Nov 15, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Stoves 720EMa - need wiring diagram
I will give you access to the handbook shortly.
Sep 27, 2009 | Stoves 720EF Electric Double Oven
How do I remove the hinges from a Blanco BOS402
Sep 13, 2009 | Ovens
Ovens Logo
201 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
