Question about Kenmore 24902 Top Load Washer
My Kenmore 80 series washer shakes uncontrollably in spin cycle.
We have just replaced the coupling in the direct drive because the machine was not spinning out. Now when we turn it on it shake violently. Have we forgot to connect something or is there a spring broken somewhere?
    Genius:
  • 1,224 Answers
Try this
the washer needs to be leveled on a flat surface to properly function rock forwards then backwards
washing machine have stablizers on there leg pegs this insures it has a proper setting on floor
if this did not help there is a spring under neith that you did not load back to bucket to keep in place
most likely it just needs to be rocked you will know if pegs are seated properly
Posted on May 07, 2008
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Just replaced a broken drive coupling on my Kenmore washer
the wigwag is bad, which has to be replaced,, you need to find out what caused the drive coupling to fail in the first place & fix that problem or else you will have the same problem again..
Aug 01, 2010 | Kenmore Washing Machines
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
337 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
