Where is the symbol of square root or cube root on my PC?
  • 415 Answers
There is NO square root symbol on ANY pc keyboard ( unless its a specially made scientific numberpad integrated keyboard).
You will have to use the windows character map in you menu to find the symbol.
Posted on Aug 28, 2010
Radical calculation
There are limits to what the calculator can display in symbolic form, and roots beyond the second (square roots) are beyond its capabilities. Even something as simple as the cube root of 2 will be displayed numerically.
Mar 21, 2013 | Casio fx-300ES Calculator
I have a casio fx-115ES and I want to do a cube root without answering in decimal forms
Sorry, but the fx-115ES can only display square roots in radical form. Cube roots are beyond its symbolic capabilities and will always be in decimal form.
Mar 08, 2013 | Texas Instruments TI-86 Calculator
How do I simplify a cubed root of a number on the fx-300ES?
It can handle square root but if result requires too much display space it will be displayed as a decimal.As to higher order roots such as cube , 4th and higher they are displayed as decimal. Sorry, there is nothing you can do about it.
Apr 18, 2012 | Casio fx-300ES Calculator
How can I find the square root of 39 on my ti-30xa? Also I would like to know how to find the cube of 9482... Help
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] =
[cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
Aug 11, 2011 | Texas Instruments TI-30XA Calculator
Trying to find the surface area of a sphere given the volume: V = 4/3 X pi X r cube problem given vol. find the surface area v = 5000 5000(3/4 pi =r cube the book reads: 3 cube before and the square...
Almost exactly the way it's written in the book.
In the LineIO mode press
3 SHIFT [xth-root] 5 0 0 0 * 3 / ( 4 * SHIFT [pi] ) ) =
In the MathIO mode press
SHIFT [xth-root] 3 right-arrow 5 0 0 0 * 3 / ( 4 * SHIFT [pi]) =
xth-root is the shifted function of the key just below and right of the big round cursor pad.
* is the multiply key
/ is the divide key
pi is the shifted function of the x10^x key in the middle of the bottom row
BTW there's no "square root" in this problem. There's a "cube root" or "third root". Square root is the second root.
May 14, 2011 | Casio fx-300ES Calculator
How do i do radicals expressions on a TI 30XA
On your calculator, in the 4th column and third row down you should see the root x symbol. In order to do a radical, just press a number and then press the root x and you shall get the square root of your number. Now in order to do this for cubed root, fourth root, etc, you have to hit the number you want to put in the radical, the 2nd key, look for the y^x key in the last column second row, and then the number outside the radical. For example, if you wanted to do the cubed root of 8, you would hit 8, 2nd y^x, 3, and you should get 2.
May 05, 2011 | Texas Instruments TI-30XA Calculator
One cube has a face equivalent to the total area of another cube. find the ratio of their volumes?
Let the sides of the cubes be a and b,
the length of the diagonal of the cube whose side is b is given as square root(3)*b
according to the given question,
a=square root(3)*b
the volume of the cube with side a is given as
v1=a^3=(square root(3)*b)^3
and the volume of the cube with side b is
v2=b^3
then their ratio of volumes is given as
v1/v2=3*square root(3)*b^3/b^3=3*square root(3)
i.e v1:v2=3*square root(3):1
Next qwasthun pwease :D
Jan 06, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
How do i do a number 'to the power of 1/2 or 2/3? cheers Brad
Power 1/2 is the same as square root: You can use the square root key to the left of the square key.
Similarly power 1/3 is the cube root. You use the [SHIFT][Square root] key sequence.
Power 2/3 is the square of the cube root, or the cube root of the square.
More generally, you can use the universal power key, marked with X with a raised white rectangle. It is between X square and log.
Ex: Calculate 15^(2/3)
15 [X with raised rectangle] 2 [/] 3 [)] [=]; the result is 6.082
The last parenthesis closes the left parenthesis introduced by the calculator.
Alternatively you can use the cube root and the x-root selections available under the MATH menu.(selections 4 and 5)
Mar 14, 2010 | Casio FX-115ES Scientific Calculator
I need help with square root functions
The square root has a dedicated key sequence [2nd][V square root symbol]
Square root of 21.2846 is entered [2nd][V square root] 21.2846 [ENTER] .
The result is`4.614.
I suspect you want to calculate the 4th root of 21.2846. If it is the case you enter that as
21.2846 [^](1/4) =2.148
Square root can be also entered as [^](1/2)
Cube root is entered as [^] (1/3)
nth root is entered as [^](1/n)
Hope it helps.
Nov 19, 2008 | Texas Instruments TI-86 Calculator
Entering a cubed root into a ti-83 plus
You can enter any root by typing the number, then hitting MATH and 5, which brings up the root symbol with the x in front of it: x√. So the fifth-root would be 5 -> MATH -> 5 and then whatever number you want to get the fifth-root for: 5x√10 for example. As someone else had mentioned, you can also raise it to a rational power: 3^(1/3) which would be the same as the cubed root of 3, but you could also type: 3 -> MATH -> 5 -> 3 and get the same answer, but looking like this in your calculator: 3x√3. The option for 4 actually is a predefined cubed-root, and the one for option 5 there is the root symbol that can be used with any number before it to get any root you want. There are no parenthesis as you get when using the predefined square-root and cubed-root functions, though, so you may want to type them in yourself if entering a long string of operations in the calculator at one time to make sure the calculator doesn't include numbers under the root that you don't want it to. But I guess it depends on preference in terms of what method you choose between the rational exponents or the root symbol (and most would go with whichever seems easiest and quickest to enter), but you asked specifically how to get the cubed-root on the TI-83 Plus, so there's my best attempt at answering your question.
Aug 22, 2008 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
