Question about LG WM-2277HW Front Load Washer
Water wont pump out must be free advice, - LG WM-2277HW Front Load Washer
  • LG Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 28, 2010
I have a haier hdc1804tw it starts,pumps out old water, fills new water, than stops. It wont activate. Any advice?
Have you had any luck with this? Ours just started doing this tonight after no problems (had it for 3 years, light use). "Feels like" a pump isn't kicking in to pump the water to the arm.
Sep 14, 2013 | Haier HDC1804TW Dishwasher
Constant beeping
probably letting you know that if has run out of water to pump and need priming.
Jun 11, 2013 | Plumbing
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
FDB251OLCC1 dishwasher wont clean top rack
Possible that the main pump for the spraying system is not working, you will need to check the INLET valve , remove and check if there is flow when the washer is switched to start, if not the inlet valve is faulty as it does not allow water to the pump.
check this link for tips to check the pump;
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Oct 18, 2011 | Dishwashers
My washer can wash but cannot drain water from thye tub. how can i fix this?
The question is pretty loose so I will do the best I can without knowing the model and type of washer but they are all basically the same.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting [ if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from a pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops].
Full and detailed advice about finding your pump filter, draining the washing machine when stuck full of water and looking for blockages can be found here - troubleshooting pump faults on a washing machine.
If this is helpful a vote with the thumbs up would be appreciated for the free advice and is you need furthur explanaition please feel free to contact me .
Thanks
Aug 22, 2011 | Samsung Washing Machines
My washing machine has two flashing lights and it want drain the water it just stops half way through i think my water pump is broken
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesn't drain then you have a blockage anywhere from the drum outlet into the pump to the water pipe if it does drian then take the pump apart and check it turns freely
Jun 04, 2011 | Washing Machines
My toploader makes noise but wont spin or drain
in some cases its the lid switch but more likely there is a block to your water pump small socks can jump through the top of the drum and down into the pump or the pump has decided to cease. or has simply blown up try by working your way through these factors remember that a washer must detect that all water has been pumped out before it will go into spin cycle.
best of luck
merry christmas
please take the time to rank this advice
Dec 07, 2010 | Washing Machines
Annovi pump wont build pressure
try force feeding the pump first, this can help to clear any dirt which might be in the valves.
you have 6 valves which are all the same , but 3 are suction and 3 are for pressure.
just take them out and put under a slow dripping tap and fill with water, if the water holds inside the valve will be ok, if it leaks just check for dirt.
hope that helps
Jun 25, 2009 | Garden
Can over heat cause by failure of water pump?
water pump in 03 max is internal inside the timing chain area. worry free, unless you have coolant leaking behind the a/c compressor bracket and down onto the ground. thats how you know if pump went. and yes, you can overheat a car if water pump fails, but maxima water pumps are pretty bullet proof, that;s why they are iternal
Jun 18, 2008 | 2003 Nissan Maxima
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
