Question about Cell Phones
My Nokia 5530 XpressMusic which keeps switching off whenever i recieve a call from someone,i have formated the phone ,the memory chip,restored the factory setings but nothing seems to work.The problem is whenever i slide to answer the phone ,in 2,3 seconds the thing shuts down plzz help its a very frustrating situation
  • Cell Phones Master
  • 17,129 Answers
This has got to do with the contacts in the phone. Please shut off and remove tthe battery . look carefully into the battery terminals for a thin film of dirt. Use some good methyl spirit / switch cleaning solution to wipe all dirt on the terminal using a cotton bud. Now wipe it clean dry.
repeat the same for the phone contacts.
Now ehen you put in the battery check if there is a gap in the battery to the terminal ,,like a play. If so use a thin sheet of paper to tighen the battery to FIT the terminal well.
The possible fault is that when the load come up on the battery as taking a call there is contact loss on the terminals resulting in the drop of voltage making the processor to shut off due to starvation.
The likelihood of the fault going into the board is not ruled out and if after this is done , the fault repeats, then it will be good to open and clean up /solder the power circuits, tighten the boards .
Look for possible dry solder or loose connection of SMD components inthe power side.
But if you are in warranty make use of the advantage and do not tamper.
Also as a last try remove the memory card and see if the fault comes in. If so scan for virus or delete unnecessary files.
hope this advice helps
Posted on Aug 28, 2010
I have a nokia 5530 xpress music which keeps switching off whenever i recieve a call from someone or make a call
I believe the problem with your phone is the battery.
Please, replace the battery with a new one.
Thanks for your patronage.
Jun 09, 2011 | Nokia 5530 XpressMusic Smartphone
My nokia 5530 screen suddenly turned black but the buttons are working fine i even hear when someone is texting me i dont know what seems to be the problem, any suggestions?
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
May 17, 2011 | Nokia 5530 XpressMusic Smartphone
Nokia 5530 XpressMusic format phone memory
It seems you are having an application problem on your phone.
To formatt your phone simply dial this code;*#7370#.
This code will completely format your phone deleting all your files.It will take your software to the same state, as you first received your phone.Use this code only if something wrong happens with your phone's software like virus attack.
It is also called hard reset.
Take care and have a nice day.
Dec 10, 2010 | Nokia 5530 XpressMusic Smartphone
My nokia 5530 is givin me problems.it won't tart up when the memory card is in place. the card has to b removed then it starts up. anyone knw why?
If you can try formatting the memory card. my 5530 had problems until i formatted the memory card so hope this helps.
Oct 18, 2010 | Nokia 5530 XpressMusic Smartphone
I HAVE NOKIA 5530 XM. IT CANNOTSEND TEXT MESSAGES. WHEN I PUT MY SIM IN ANOTHER PHONE , IT SENDS MESSAGES, MEANS THE SIM IS FINE, AND WHEN I PUT ANY OTHER SIM IN MY NOKIA 5530 IT SENDS MESSAGES, MEANS THE...
nice noon...you need go to cellphone repair shop anf try to reprogram or master reset your phone,,i think the problem of your phone is software..good luck....
Jun 22, 2010 | Nokia 5530 XpressMusic Smartphone
I have a nokia 5530 expressmusic how do i unlock it to recieve all networks
Use this site to unlock your mobile...
1 - Switch on your Nokia 5530 Xpress music without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5530 Xpress music.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5530 Xpress music would then display the message "SIM Restriction Off" and will be unlocked!
If you need unlock code...You can get the unlock code here theunlockarena.com
Apr 25, 2010 | Nokia 5530 XpressMusic Smartphone
My nokia 5530 not display showing
Just restore factory settings .
Here is the way :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
[by the way that will restore factory settings of your device ] . back up all of your important data before you do it ]
good luck
rate if useful please !
Feb 08, 2010 | Nokia 5530 XpressMusic Smartphone
Nokia 5530 wichs keeps shutting down
my nokia 5530 powers off when i call someone.
Jan 11, 2010 | Nokia 5530 XpressMusic Smartphone
How to formate the phone
nok 5530 dial the call phone wil be hang
Jan 06, 2010 | Nokia 5530 XpressMusic Smartphone
Cell Phones Logo
94 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
