Question about Microwave Ovens
Hi I have a juice fountain but not sure which model as it doesn't say on the machine. I don't have a manual and can't manage to take the main compartment out to clean it! Pulp is currently rotting inside - can you help?
  • 857 Answers
Follow these steps to clean ur juicer.
•1
Turn off and unplug the Juicer to avoid injuring yourself. Pull the pusher up and out of the chute. Pull the locking bar down, so it touches the counter. Pull the lid up, removing it from the juice receptacle.
•2
Look at the bottom of the pulp collector. Notice a lip that sits in the base of the juicer, like a puzzle piece. Pull the collector away from the juicer's base while pulling it out from the lip at an upward angle of about 45 degrees. Remove the blades and the filters by twisting their receptacle and using one hand to pull up on it and the other hand to pull down on the unit's base. Leave screws in place.
•3
Remove the spout. Look at the bottom of the receptacle and find the locking mechanism, which is round with a metal interior. Turn it counterclockwise, so the spout's pivot arm meets the plastic notch. Lift up on the spout, and it will separate from the receptacle.
•4
Run your sink three-quarters full of warm water. Add a gentle dish soap and mix it in with your hands. Place all the juicer's parts in the soapy water--except the base, which has electric components that could be damaged by the water.
•5
Wet a cotton cloth, wring it out and use it to wipe the base. If it is heavily soiled, scrub the base with a toothbrush dipped in the soapy water. Make sure you don't get water inside the base. Wipe it dry with a second cloth.
•6
Clean all of the juicer pieces in the sink with a kitchen brush, then rinse them with cool water. Dry the parts with a dish towel before reassembling your Juicer.
Posted on Aug 28, 2010
E Wave Above Range Microwave Model KOT152 UB
Please check your e-mail inbox. I answered privately this is detail.
For others, it may need circuit board repair. The service manual is here and the disassembly video is here.
Jun 09, 2013 | Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
I have a Singer Juice Giant II but no instruction manual. Where would I find the instructions?
HELLO.
Way out to the problem.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
Sep 19, 2011 | Microwave Ovens
Replaced the touchpad and put it all back together. It now heats, but the oven light doesn't come on and the turntable doesn't rotate. Do you think there's a loose wire?
First check is the main fuse of the unit. On countertopunits, you will need to take the shell off. The fuse will be close to where thecord comes through into the unit. OTR units, this main fuse is usually behindthe control panel or possibly behind the vent. Usually the fuse is obvious ifblown, otherwise test with an OHM meter, if open, replace fuse. Some brands will also have a thermal cut-off fuse in theincoming voltage line to the control board. This thermostat looking fuse isusually above the oven cavity somewhere under the outside shell. Sometimes youcan get to it through the vent of OTR models. Test with an OHM meter, replaceif open. Forturntable: First, make sure the turntable coupler under the glass dish is notbroken. Second, on the control board, find the turntable relay and test forvoltage. Some turntable motors are 24 volts DC, so make sure you're testing thecorrect voltage. If no voltage from the control board, then replace the controlboard. Otherwise head towards the turntable motor. On OTR models, you can get to the motor by un-screwing thebottom panel on the microwave. On countertop models, there will either be aknockout or screw on access panel. Check for voltage at the motor. If novoltage, check the wiring back towards the control. If voltage, then replacethe turntable motor. Hope this will help you. Good Luck.
Sep 03, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Hi, I stupidly turned on my brand new Francis X7 machine without using a transformer (I bought it from the US, used it in Malaysia), and of course, something blew, and it now doesn't work at all. Any...
The machine is made to work with 120 volts and you have plugged this on a 220 volt mains circuit thereby blowing up the fuse, or the power circuit, possible heater and the main controller unit board.
A step down transformer was needed to work this unit safely . Now unless the unit is opened the damage cannot be confirmed but if you are lucky the fuse would ahve blown and saved the rest. if so test it with a new fuse using a 220 to 120 volt convertor.( transformer with good rating)
Jul 05, 2011 | Microwave Ovens
Russell Hobs Juice Lady ....10007 it makes a lot of noise and is not juicing ...what is wrong? we don't have the user manual
THIS HAPPENS WHEN THE COUPLERS OR THE SHAFT ARE WORN OUT. REPLACE THE SAME AND IT SHOULD RUN FINE(THE PART CONNECTING THE JAR TO THE BODY)
REGARDS.
Jul 03, 2011 | Russell Hobbs Microwave Ovens
Operating manual for WE100PC juice extractor
the JEX328 is the same machine as the WE100PC. You can get the manual on the link below.
http://www.waringproducts.com/ret/share/man/12_man.pdf
May 04, 2011 | Microwave Ovens
Hi, I have lost my manual for my JE7700 Smoothie Juice Bar 2 Speed Blender, I was wondering if you know where I can get one?
Try calling Kenwood directly at 023 9247 6000. You should be able to order a manual directly from them.
Oct 31, 2010 | Microwave Ovens
Looking for a power juice manual
Mention the Make/model of set so that we are able to help as many models are available.
Respond
Sep 24, 2010 | Microwave Ovens
I am looking for the manual for milex mean juice machine MMJ001
Did anyone get the manual for the Milex mean juice machine...Ours works but is awkward to take apart.. and we were just looking for manual to see if it was explained.....
Aug 19, 2010 | Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
