Question about Goodman CLQ36AR49 Air Conditioner
The fan on my outsie unit of my grand air heat pump won't turn on. The compressor hums. If I manually turn the fan it will run but very slowly.
  • 909 Answers
Your description is possibly a bit vauge for the problem it could be, but starting from the compressor, question is "can you hear the compressor running"? If you can then switch off quickly and check the cooling fan capacitor. almost certainly it has popped.If it has, and even with a new capacitor it wont start, then a complete condensing fan unit is required.If the compressor isnt running, then one of a few things could be the problem. A- The voltage getting to the compressor or the cap, is not correct which points to a problem with the board. B- If the compressor is jambed,(siezed),then it is bringing the voltage down to the point where even the fan cant run. Need to check those points to determine the next course of action.
Posted on Aug 28, 2010
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
My air compressor just stopped working completely,has power to it and can turn the fan so its not seized but was gonna start by checking the reset relay and what appears to be a capaciter. just looking for...
The first thing to check is the thermal protector (circuit breaker). It is a small black button mounted on the housing on the back side of the pump motor. The unit will have to cool down before the button will reset. Usuall causes for the thermal protector to pop are: running the compressor on an extension cord, running the compressor on power lines or circuits that can't carry enough amps to run the motor, or little or no oil in the compressor causing excessive friction and heat buildup. If the thermal protector isn't tripped the next thing to check is the pressure switch. If the springs inside are broke or damaged they won't trip the switch to turn the compressor on. If the capacitor(s) are bad the motor will hum and/or try to turn but not have the power to start spinning.
Apr 27, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Jul 29, 2010 | Heating & Cooling
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Have a duo therm penguin heat pump a/c when turning it on the compressor humms but no fan. the fan gets pretty hot upon the roof after 20 sec of operation. the main hot wire to the unit is pulling 18.5...
check the cap for the fan. Will the fan start if you spin it when you hear the humming. Check the lock rotor amperage for the compressor to see if it is hung up. The cap if it is shared could knock out both the fan and comp so check both.
Aug 12, 2009 | Heating & Cooling
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman CLQ36AR49 Air Conditioner Logo
189 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
