I have bought an additional remote which I must programme with my centurion sliding gate motor. I need some assistance, but I don't want the other remotes to go out of sync. Please assist. Thanx Dawie
Steps to Programming Centurion Nova Remotes
1. Unlock the motor cover with your Centurion Key, remove this cover.
2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase.
3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins.
4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate.
5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button.
6. If further Remotes/Transmitters are to be added to the system, repeat step 5.
7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins.
8. Close the enclosure, place the motor cover back onto the motor and lock in place.
Posted on Nov 03, 2010
  • Ramond Schuch
    Ramond Schuch Oct 22, 2013
    Tried with 2 remotes now and it still doesn't work. The LED stays lit, even with holding the button on the remote for nearly a minute. Please help
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
How to program a ET BLU MIX remote on a older type centurion d5 gate motor
Ask the shop what to do when their suggestion does not work.
Oct 02, 2014 | Televison & Video
How do i programme my sentry remote control to operate my centurion d3 motor gate
Programming procedure is too much, and is not practical to type in all here by this window. If you wish to get more details, check these links.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy
Sep 25, 2013 | Zenith DBZN-311 Remote Control
How to programme a digikey 4 button remote on a centurion d3 gate motor
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 08, 2012 | Cars & Trucks
How to programme a nova 4 button remote on a gemini gate motor
It's important to know that the Nova remote controls are not compatible with the Gemini gate motor. In order to get these remote controls to work with your Gemini gate motor, you'll need to install a Centurion receiver first (see http://www.centsys.co.za/upload/product_link_files/CS37_Nova_Receiver_Instructions_1031.D.05.0012_4.pdf). Once the Centurion receiver has been installed on your Gemini gate motor, follow the programming instructions as per the leaflet that accompanied your brand new Nova remote control, or download the instructions from http://www.centsys.co.za/upload/product_link_files/English_Transmitter_InsertCS37_1031.D.02.0027_1_Nova.pdf
Feb 22, 2012 | Televison & Video
I have bought 2 new remotes for my centurion gate motor and the shop assistant told me how to program them.....except it doesn't work - please can someone give me step by step instructions on how to do...
On a D5 Motor To program the first remote place the jumper on in learn mode over J2 and Central Pin after it has completed flashing remove the jumper. Press the button on the remote you want to program, wait until the gate starts moving. To program addtional remotes use the master remote. First remove the jumper so that the 3 pins are exposed. Press the button on the master remote and hold it in. Notice that the LED next to the pins starts flashing after it has flashed 11 times release the button. Now press the button on the second remote and hold it in it should learn the signal.
Jan 13, 2011 | Televison & Video
I need to programme extra remotes to open and close my centurion gate motor
You can call the Technical Support Hotline at 0860-236-887 or you can e-mail at support@centsys.co.za.
Nov 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Jul 15, 2009 | Home Security
Televison & Video Logo
1,834 people viewed this question
Top Televison & Video Experts
Electro Med Services...
