Question about Acer Aspire 5520-5156 Laptop
I split a drink on my acer aspire 5535 laptop and when u turn in on the light comes on the fan spins for a couple of seconds and then stops, the lights still on but screen in still blank, any ideas what is wrong? thanks
  • Acer Master
  • 11,800 Answers
The motherboard has been shorted and you must replace it.
Posted on Aug 28, 2010
Acer Aspire fan stops after starting led light stays on
Same thing happened to mine. My fan just needed replaced.
Dec 21, 2013 | Acer Aspire 5610-4648 Notebook
Locating the motherboard battery for Acer Aspire 5535
i think, it is under the fan, but it is glued in something ? maybe you can remove the keyboard, and clip of that blue/white cable on the left to flash the bios ???
Jul 21, 2012 | Acer Aspire 5535-5050 Notebook
Power light on computer and nothing else
Remove main battery to see if it will start up, no change! pull the ram memory out one at a time and try again, if still nothing! the DC jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop must be dismantled to assess the situation.
May 08, 2012 | Acer Aspire 5535-5050 Notebook
The machine has overheated and all I get now is the light and the fan turns for a couple of seconds then goes off.
uh oh. you could try and clear the cmos and see if you can erase the error code. do this by removing the battery and holding down the power button for 30 seconds. the uh oh, is because you may have damaged the cpu. hopefully not!
Jul 12, 2011 | Acer Aspire 5535-5050 Notebook
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
Laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Jul 16, 2010 | Acer Aspire 5535-5050 Notebook
Grinding noise when fan spins fast
Try cleaning out the fans before going to the bother of replacing it. There maybe some debris stuck in it causing the strange noise. A can of compressed air often removes most of the dust and debris but on occassion it is necessary to open the case and manually clean the fan.
Generally if its grinding and clicking noises it will be the hard drive the fans will cause more a whirr than a grind
May 05, 2010 | Acer Aspire 5535-5050 Notebook
Buzzing sound in Acer Aspire 5535
I've come across this before and it turned out to be the soundcard driver. See if there's an updated driver on Acer's website.
Strange buzzing can also be caused by a stuck or damaged key. Does pressing ESC help at all?
Unlikely to be the hard drive. They crunch and grind but don't buzz, unless they're completely knackered, when they can give you a three-tone buzz sound and won't spin up at all.
Hope that helps,
Matt
Aug 24, 2009 | Acer Aspire 5535-5050 Notebook
My fan is constantly on
U go to bios and desable always on fan,now fan working properly
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5520-5156 Laptop Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
