Question about Sewing Machines
While sewing, the needle suddenly hit the side of the foot-plate which bend the needle, but now the entire machanism is stuck and won't move up or down. How can I fix it and what is the cause of the problem? Thanks .... Catherine
    Scholar:
  • Sewing Machines Expert
  • 176 Answers
Hi there
1- how old your machine ? please check needle par play left and right or no? maybe lower needle bar bushing need to change.
2- maybe ur presser foot played need to change it but check firist.
3- sometimes when needle is broken there is small metal goes insaide the hook and make it dosn't move up or down, if you can adjust timing for hook please remove the hook and check your machine by hand move or not?
4- maybe some thread goes insaide the finger ( stopper for hook ) check this earia .
Best regards
ashraf abozid
aabozid@hotmail.com
Posted on Oct 30, 2010
My needle is stuck in the plate
needle has bend remove power from mains supply and remove the needle then fit new needle
Aug 04, 2012 | Singer 2250 Tradition
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
103 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
