Question about SanDisk Sansa Clip MP3 Player
Sansa clip i try to charge it and it does not take the charge or completely show a full charge even over night, does it need to be off?
Assuming charge is from computer or laptop, you need the following programs: Windows XP Service Pack 2 & Windows Media Player 10 or 11. Good luck!
Posted on May 21, 2008
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk-sansa mp3 is not getting charged even though its connected .Its a new piece and what should i do
There is a reset switch a small hole through which you can use an office pin to reset. After this use the USB cable to charge from your PC. If any file was loaded use the PC to get access to the memory. Do a full scan of the memory and delete any malware in the sansa.
After this the set might take up charging,if not you must be able to get warranty on the device if it was bought with warranty.
Hope you try this out. good day
Aug 16, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip lost all the music I had stored. It
You go to Settings, check System Info, check number of songs in there. If they are existing, you should change to MTP or MSC to play it. Or go to Settings, Reset All, Yes. Try it.
If you accidentally formatted it, can't restore them.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
Cannot tell when sansa mp3 player is fully charged.
Make sure the hold switch is not engaged - it will interfere with the charging process. Here is a link to the full user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
When i take off charge
That is normal behavior for the player. The functiosn only work AFTER you've disconnected it from the computer.
-Tha Mp3 Doctor
Oct 27, 2008 | SanDisk Sansa Clip MP3 Player
Screen says its disconnect it won't change ....
your might have to let the battery die down completly
then connect it again and see what happens
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Battery won't show full charge
I called sandisk. You have to have service pack 2 on your windows XP and you have to have Windows Media Player version 10 or 11. One one of my laptops I had version 9 and it wouldn't work, I changed laptops and it works just fine.
Jan 17, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
