Question about Pacific Digital PRIMEVIEW801 Video Recorder
I have a MVM High-Definition Digital Set Top box. It is connected through my video. I can play a video and the channels change on the set top box but nothing shows on the TV screen. I have a "lock" button light showing on the box. Would this be the problem? I have consulted the book and cannot see anything mentioned re the "lock" button. I would appreciate your help.
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
Mvm digital set top box stbhd09 device code
0254,0238,0270,0219.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 25, 2014 | Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
I have purchased a JNC DB961 Set Top Box but It does not have instructions so I do not know how to install it.
It's a standard definition set top box for high definition channels, I'm an idiot for buying it too
Sep 03, 2011 | Televison & Video
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
I'm confused about HD (high definition) and digital
In Australia analogue TV signals will be phased out and finished by the end of 2009 (I think).
If you have a standard analogue TV you won't be able to receive any more free to air analogue TV programs when they stop brocasting these TV signals. To recieve the new digital signals you need to buy a digital set top box (which receives digital TV signals and converts it to analogue signal that can be displayed on your old TV). The set top box will only receive Standard Definition signals and this is a lower screen resolution that is available from High Definition signals.
Digital TV signals offer approx. 15 TV channels ln High definition and Standard Definition, different programs channels will be available from the same TV broadcaster, although the High Definition pograms will also be repeated on one of the Standard Definition channels.
High Definition gives a sharper image than Standard dedinition, but you may not notice much difference because it depends much on the material you are viewing, You will notice how clear DVD and BlueRay movies are compared with the VCR tapes. To get the best images from DVD movies your player must be connected to the HDMI connector on your High Definition TV (provided your DVD player has one, usually BlueRay players will have one, they also will play normal DVD disks).
If you purchase a new High Definition TV you will also be able to receive all the Digital TV programs. Currrently these TVs are avail in Plasma or LCD screens and there are newer technologies within a few years. The Plasma screens use twice as much energy (electricity) as a LCD screen. It is suggested that the viewing distance to the TV should be 3.5 times the size of the TV screen.
Hope this answers your query.
Get back to me if you have any more questions.
Mar 03, 2009 | RCA TruFlat 27F520T 27" TV
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Pacific Digital PRIMEVIEW801 Video Recorder Logo
404 people viewed this question
Top Pacific Televison & Video Experts
RSole
Are you a Pacific Televison and Video Expert? Answer questions, earn points and help others
