Question about Hughes Computers & Internet
I am using HX50 model of HUGHES MODEM. The system was working normally until recently when the indicator lights started flashing. Although this did not stop us from accessing the internet, the modem sometimes switches it self off. However when I restart the modem, things become normal again lasting for about one to two hours before switching off again. .
SOURCE: Default IP Adress of the modem Hughes HN7000S
The Hughes addresses are 66.82.4.8 and 66.82.4.12.
Posted on Mar 08, 2008
SOURCE: "Lost" modem access code
go to dslreports.com, under forums see if there is a specific help for your telco or modem type. They are very helpful
Posted on Jul 26, 2008
mastersaintx
  • 928 Answers
SOURCE: slow modem
An option that you can take is to possibly update the firmware of your modem. If that does not work contact your internet provider for a replacement depending on the arrangement you have. (Whether or not the modem is in rental or purchase plan) if its under warranty have it replaced.
Posted on Oct 23, 2008
kiboiz
  • 6 Answers
SOURCE: The ethernet light won't turn on my modem anymore
hi...
try to check the ethernet adapter on your computer...if the ethernet cable works fine with the other computer and the other one does not, then probably, the NIC CARD or ethernet adapter is defective...i advise, if you have someone or a technician or a friend who knows how to check...then you can do such,..or if it's a laptop..then youn can bring that to any computer stores and they have technicians there to check freely your case,k...
hope i give you something that may help a little with your concern....
happy new year!!!!!
Posted on Jan 01, 2009
Idaho_Biker
  • 32 Answers
This site may work for You:
http://www.softwaredriverdownload.com/download_siemens_speedstream_41004200_dsl_modem_manual.html
looks like a manual install of the driver packet. but it's FREE! Good Luck
Posted on Feb 20, 2009
What is a bonded channel signal
A 'bonded channel' is where the modem combines two or more channels together, for increased bandwidth.
The first light <Power> should be green, indicating power is on.
The second <Receive> light can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for downloading. That is too say, it is bonding(higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The third light <Send> can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for uploading. That is too say, it is bonding, (higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The fourth light <Online> is green, only....
If green and flashing, it is scanning for a connection.....
If green and not flashing, it is finished scanning....
The fifth light is the WiFI indicator of network traffic. (It also is used for WPS pairing, which I doubt you will use. Just stick with the WiFi indicator function...). It should be green, normally..., or non-WPS....
If #2 is blue, and 3# is green, normally...., I suspect that there is too much loss in your in-house system of wiring, and splitters. If that is the case, try putting a 8-12dB 'tap', in series with the whole house. That way, the loss is minimized for your modem to 'send' high bandwidth stuff upstream to the cable guys.... Be sure that the modem is connected to the 'tap' port, the house to the 'out' port, the cable company to the 'in' port of the tap block. I pasted a couple of examples of taps, at the bottom of this, to show the port labels. The tap loss to the rest of the house, is minimal to how well everything else works. I get a +15dB signal from the cable company. But, too many splits, left my modem in low speed upload mode. By-passing the splitters of the house, by adding the tap as only loss to modem uploading, my blue light always stays on. I also added an UPS, to cover power failures, and glitches. That was a well spent $50 special!
a3e73f03-c380-49da-8c63-30f45940ca66.jpg ef068fc8-f053-49ce-a577-d352db809e0b.jpg
Jul 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I wnt to buy a used hughes kettner replex but the blue lamp does not glow. Does that mean there is a signifecant pproblem i should worry about.iit sounds great but when bypass mode not to loud.
Although I can not be 100% sure about the functionality of the Hughes Kettner Replex, I would have to say that the blue light is just a power indicator light. Bulbs go out from time to time, but if the sound is good and is what you are looking for, then it seems like it should be a good buy.
Jan 18, 2011 | Audio Players & Recorders
I have a Volvo S80 2000 model Recently I have lost all contact wih my dashboard. Lights, and all dials fail to function, although the car starts and runs as per normal. Exterior lights and indicators all...
I have the same prob except mine is intermittent at the mo. Spoke to an electrical mechanic today who informs me that a new dash is needed. According to other forums second hand one's don't work but it may be possible to send yours off and have it repaired.
Jan 12, 2011 | 2000 Volvo S80
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Hugesnet HN7000s Modem Only the power light comes on.
what seems to be the issue? i'm a hughesnet install/repair contractor
as a catch-all heres some places to start....
we'll start with the 5 lights on the front of the modem:
the top one tells you if the ethernet cable is plugged into anything.... if it's off check to make sure that cable is plugged in. if it is....replace the ethernet cable, they are cheap and available virtually everywhere from walmart to radio shack.
the next 2 lights are for transmit and recieve.... they should blink a lot but not in any particular pattern. if either of these lights is acting funny you could have cabling issue (ie: improper fitting, rust on the line, messed up groundblock, or even a severed cable), a misaligned dish, or even a blown radio (its far more common to blow out the radio than to blow out the modem...especially on those 7k systems) you might be able to correct the cable issue yourself with the right tools, but DO NOT attempt to re-align your dish....its touchy. btw i should state that if hughes catches you monkeying with your hardware they'll yank your warranty....either dont do it or dont get caught.
next light down is the "system" light. this tells you if you are connected to hughes. this light will be OFF of there is a problem with the transmit and recieve. if there is no problem with the transmit/recieve and this light is off there could be a billing problem at the other end. contact support.....you'll get a guy in india or the philipines or something that says his name is "harry" or "john" or "fred" or something american sounding. this always cracks me up.
next one down is the power light. if you have other lights on but the power light is off it indicates a broken modem...no way around it, you're gonna need a new modem.
ok, on with the trouble-shoot. if your top light is on you should be able to use your computer to look at the modem using a browser (firefox, internet explorer, safari, etc) type in 192.168.0.1 in the address bar. you should get a interface with some colored buttons across the top. the system status button should be green...any other color means trouble. the other 3 should be blue. if you cannot connect to the interface the trouble is user-end...bad ethernet cable (as mentioned before) or something beyond-the-line from the modem is messed up (router, computer, or something)
if you have any red lights you can click on them to see what's wrong. any problem areas will have red flags with error codes next to them. write these down as they are useful to diagnose what is actually wrong with the system.
if your system status button is yellow, click it....most likely you have "fapped out" (violated hughes' fair access policy) btw you can look at your signal strength too....there is no way to tell you what the signal strength should be since i dont know which bird (satellite) you're pointed at. each bird has a different acceptable signal strength.
let me know what you find and i'll see what i can do.
Mar 28, 2009 | Hughes DIRECWAY Professional Business...
Modem power adaptor
On the bottom of the Modem, it usually lists the type of voltage/current ratio, for example, My modem is a 12VDC in, output is .75A Through the modem. Each modem has its own power requirements. Therefore if they dont match, you have the chance of either underpower (which means no use) or overpowering (and killing your modem permanently)
Best suggestion si the same as above by cnavarro, Buy the Right power supply for it, dont just try anything. get the matching one. Otherwise it will be Incident A or Incident B. Neither would work well, and you would end up buying a new modem all together.
Oct 30, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Does a satellite internet network require a special wireless router or will a DSL wireless router work? (Huges satellite)
They will provide you connection on their satallite modem. You can use any wireless router of your choice with the same.
Regards
Sammy
Aug 27, 2008 | Computers & Internet
Mar 06, 2008 | Computers & Internet
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
249 people viewed this question
Top Hughes Computers & Internet Experts
David Payne
David Payne
Are you a Hughes Computer and Internet Expert? Answer questions, earn points and help others
