Question about Samsung SyncMaster 214T 21.3" LCD Monitor
SyncMaster 214T Flicker Repair
Thank you for a great solution. I have the exact problem, and will look for bulging capacitors... Can you share the method you used to open the monitor so as to not damage the plastic?
  • 2 more comments
  • optimus_prim May 15, 2008
    The picture of my Syncmaster 214T flickers (kind of keeps blinking).
  • Anonymous Feb 25, 2009
    My screen just started flickering RAPIDLY...and it won't stop. I've tried everything I know to do. The monitor is not that only...only about 18 months.
  • Buddy Mcsparrin May 11, 2010
    Hello, It sounds like you have a monitor with a common problem. After a few years some LCD monitors will
    blow a power supply. The problem is caused by parts called capacitors
    overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine.We
    just posted a repair guide showing how to remove the case and replace
    the parts. The capacitors do need to be installed with the correct + and
    - connections, note the stripe on the old one and insert the new one
    the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution. Buddy Corporate Computer www.ccl-la.com Over 21 years of computer and printer support/repair
    will blow a power supply. The problem is caused by parts called
    capacitors overheating in the confined space of the monitor. If you are
    good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.
    We just posted a repair guide showing how to remove the case ans
    replace the parts. The capacitors do need to be installed with the
    correct + and -
    connections, note the stripe on the old one and insert the new one the
    Buddy
    Corporate Computer
    www.ccl-la.com
  • Samsung Master
  • 1,684 Answers
We have a step by step repair guide posted on our web site at: www.ccl-la.com. The guide shows how to dis-assembly the monitor and what needs to be replaced.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 27, 2009
Sycmaster 204T works great for 20 seconds then screen blanks
Hello Carl,
That problem could be caused by either bad capacitors on the power supply board or a bad back light bulb in the panel. The first thing to check would be the capacitors on the power supply board. Here is a link with a few pictures of how to dis-assemble the unit and what to look for. The tops of the capacitors should be flat, if they are domed or have any bulging then they need to be replaced. If all of the capacitors look good then it is most likely the back light bulb. This can be replaced by it is much more involved.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Sep 24, 2012 | Samsung SyncMaster 204t 20.1" Flat Panel...
Samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
I hope this helps,
BuddyMc
Jun 07, 2012 | Samsung 215TW SyncMaster 21" LCD Monitor
The backligt stay fickers contineu
Flickering or wavy picture is a very common symptom of failing capacitors in the power supply board. This is a very easy repair, it just requires replacing the 6 capacitors on the power supply board. Here is a link to a repair guide for the SyncMaster 214T which uses the same NP-20 power supply board so the repair information will be the same.
I hope this helps,
BuddyMc
Dec 22, 2011 | Samsung 215TW SyncMaster 21" LCD Monitor
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
Our samsung 214t will not display a decent image until it has been turned on and off a few times. Any thoughts?
You have a power supply in the monitor that is failing. This is a known issue with these great monitors. It is a simple 20 minute repair. We have a step by step repair guide for ts model posted on our site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ The repair involves replacing 5 small parts called capacitors. If you don't want to do the repair yourself we do offer a repair service for this model, the repair service runs $32 plus shipping.
I hope this helps if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 07, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214T wakes up from hybernation flickering (Windows 7)
A flickering display usually indicated a failing power supply. Check out our web site at www.ccl-la.com We have a free step by step repair guide for the 214t that will show you how to open the case. Once inside look at the power supply for parts called capacitors. The tops should be perfectly flat and I would bet your have bulges which indicate they are damaged. If you find bad caps and them replace them you should be back going without any flickering. Many LCD monitors will have issues after 2-3 years of use. If you have any more questions just let us know.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 19, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 214T flickers
Hi There,
I managed to fix my Samsung SyncMaster 214T from that flickering. Just changed 3 capacitors and it worked fine!!
Jun 01, 2008 | Samsung SyncMaster 214T (Silver) Monitor
214T - flickers radidly
Yes,
A flickering screen indicates the power supply is not properly filtering the output power. This happens when the capacitors on the power board start failing. Here is a link to a repair guide that shows how to dis-assemble the unit and what to look for and replace on the power supply board. The repair guide also has videos showing the process.
BuddyMc
May 02, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
1,906 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
